rikur
rikur
Posts: 132, Visits: 632
(updated August 2018)
For High Sierra:
Known issues:
How does it work?:
rikur
rikur
Thanks for the Mac port.
I have installed SkyDemon for Mac 2018 for High Sierra and have been able to update the version to 3.10.5.
Unfortunately the "What's Here menu" is just not popping up. Strangely enough, the menu does work on my MacBook Air, but not on my iMac. Any ideas? (I have completely removed and reinstalled the app and have updated the charts)
Yes - this can be fixed.
Locate Skydemon, and right click.  Select 'show package contents'
Then run 'Wineskin'
Choose 'Screen options' and tick 'Use Mac Driver instead of X11'
Then Done, Then Quit
I'll include this by default in future builds
SmoothFlyer
S
Too Much Forum (129 reputation)Too Much Forum (129 reputation)Too Much Forum (129 reputation)Too Much Forum (129 reputation)Too Much Forum (129 reputation)Too Much Forum (129 reputation)Too Much Forum (129 reputation)Too Much Forum (129 reputation)Too Much Forum (129 reputation)
Posts: 11, Visits: 58
rikur - 10/6/2018 6:38:02 PM
Then run 'Wineskin'
rikur - 11/20/2015 9:44:00 PM
Bajab - 11/21/2015 7:19:48 PM
rikur - 11/21/2015 7:25:13 PM
rikur - 11/22/2015 8:57:10 PM
rikur - 11/23/2015 6:34:45 PM
C82R - 11/28/2015 9:23:29 PM
rikur - 11/29/2015 7:52:26 AM
rikur - 11/29/2015 8:53:56 PM
                 hii
                 hii
rikur - 12/2/2015 10:30:52 AM
guille - 12/2/2015 6:12:04 PM
rikur - 12/2/2015 6:13:26 PM
Gernot - 12/6/2015 1:30:12 PM
rikur - 2/4/2016 4:08:08 PM
reimomo - 3/3/2016 7:50:58 PM
reimomo - 3/3/2016 7:52:07 PM
rikur - 5/5/2016 10:41:45 AM
guille - 5/20/2016 7:47:28 AM
rikur - 5/20/2016 8:49:48 PM
guille - 6/2/2016 12:09:59 PM
rikur - 6/2/2016 7:26:25 PM
rikur - 8/2/2016 6:54:12 AM
ADW666 - 9/12/2016 5:15:21 PM
rikur - 9/12/2016 9:18:12 PM
ADW666 - 9/12/2016 9:22:32 PM
                     + x [quote] [b] ADW666 - 9/12/2016 9:22:32 PM [/b] +...
rikur - 9/12/2016 9:49:55 PM
rikur - 9/17/2016 11:22:51 AM
KFL - 10/8/2016 7:21:31 AM
rikur - 10/16/2016 9:56:20 AM
                     + x [quote] [b] Cessnaoui - 10/17/2016 2:45:57 PM [/b]...
rikur - 10/17/2016 2:54:31 PM
     Any new?
rikur - 12/6/2016 1:11:19 PM
rikur - 2/22/2017 1:16:32 PM
on5ap - 2/22/2017 1:49:37 PM
rikur - 3/18/2017 8:52:32 PM
nestor - 4/10/2017 8:49:14 AM
rikur - 4/10/2017 8:53:43 AM
rikur - 4/29/2017 1:51:12 PM
on5ap - 5/1/2017 10:26:57 AM
rikur - 5/1/2017 3:39:14 PM
on5ap - 5/26/2017 10:47:14 AM
IvanS - 5/22/2017 4:36:23 PM
rikur - 6/25/2017 4:31:58 PM
rikur - 6/25/2017 7:25:49 PM
                         Yeah, I see. I've just left it as is, for now. Playing with the DPI...
Miked - 7/18/2017 7:13:41 PM
rikur - 7/18/2017 7:19:15 PM
rikur - 7/21/2017 8:15:47 AM
guille - 7/24/2017 2:11:42 PM
rikur - 7/28/2017 8:46:08 PM
rikur - 7/29/2017 11:13:28 AM
rikur - 7/29/2017 7:07:47 PM
rikur - 7/31/2017 7:41:48 PM
rikur - 7/31/2017 8:35:40 PM
                         That worked...! Don't understand why, though, but anyway. Thanks a lot...
rikur - 9/27/2017 3:43:18 PM
                 ‌I will do the step tonight ... wait & see.
SUBA - 10/28/2017 7:06:08 PM
rikur - 10/31/2017 1:07:58 PM
rikur - 10/31/2017 1:22:28 PM
rikur - 12/23/2017 6:51:35 PM
OmeRon - 1/2/2018 1:14:16 PM
rikur - 1/4/2018 10:27:21 PM
             Some suggestions in this thread:...
rikur - 2/21/2018 10:11:26 AM
                 Much appreciated! Working now. ‌ ‌ ‌
ADW666 - 2/21/2018 2:31:50 PM
rikur - 3/17/2018 8:41:50 PM
rikur - 5/25/2018 7:56:17 PM
rikur - 5/26/2018 11:49:59 AM
TJ - 6/30/2018 3:40:11 PM
rikur - 8/7/2018 7:11:36 PM
                 10.13.6
rikur - 8/12/2018 12:16:14 PM
rikur - 8/12/2018 12:28:48 PM
rikur - 8/20/2018 7:30:04 AM
rikur - 8/20/2018 11:15:55 AM
rikur - 8/20/2018 11:43:32 AM
rikur - 8/21/2018 1:52:29 PM
jryam - 9/14/2018 11:06:12 AM
rikur - 9/20/2018 7:37:29 PM
jryam - 9/21/2018 11:04:25 AM
gratd - 9/20/2018 4:23:22 PM
JWB - 12/20/2018 2:12:24 PM
rikur - 12/20/2018 2:40:19 PM
rikur - 3/1/2019 8:31:02 AM
rikur - 3/8/2019 8:27:22 AM
                         I wouldn't estimate that due to Apple Rumors, making ipad apps running...
rikur - 3/25/2019 9:31:40 AM
rk19 - 3/27/2019 3:15:59 PM
gratd - 4/2/2019 10:19:19 AM
guille - 4/3/2019 10:33:03 AM
guille - 4/8/2019 4:38:35 PM
gratd - 4/30/2019 8:26:26 AM
rikur - 5/10/2019 8:33:41 AM
                         Fine! Same, as said, for näme. Really NO troubles at all. Even the...
                 Good news ! Thank you for the feedback :-)
fzahn - 5/18/2019 10:08:57 AM
gratd - 6/9/2019 12:23:11 PM
             Yes.
                 Huge Thanks - downloaded and worked first time.
gratd - 10/8/2019 9:41:30 AM
rk19 - 12/22/2019 2:38:56 PM
TJ - 3/3/2020 10:45:33 AM
Gourls - 1/31/2020 2:11:33 PM
arne - 3/29/2020 4:13:30 PM
TJ - 3/29/2020 9:38:37 PM
TJ - 3/30/2020 1:43:16 PM
MOIN - 7/28/2020 7:59:06 AM
