SD on iPad, PowerFLARM - Connection problems
drnicolas
drnicolas
Posts: 99, Visits: 114
I recently started flying an aircraft which is equipped with a PowerFLARM device and an Air connect. SD on my iPad, PowerFLARM and airconnect together seem to work.
My WLAN on iPad connects automatically to the Air connect and SD then can see FLARM and ADS-B targets.Also it seems to get its position from the FLARM-device.
So far it is working. But only if I have plenty of time and do not start using SD too early
In  real life , I have  Problems with the connection:
- Normally it takes time to connect to the speciifc WLAN of the air connect-device.
- If  I wait  with starting SD until the iPad has connected, then it works
- If I start SD  before the WLAN connection is etsablished, then SD fails to connect to the FLARM device‌. I see a message box that the connection has failed.
‌And it keeps failing! This does not change even when the WLAN-connection is established later on. I see that box again and again. I have to kill SD and start it again. The it works.
The next problem is probably related to the behaviour above:
I have my iPad in a protective case with  a magnetic cover. Closing the cover sends the iPad‌ to sleep.
When opening the case, SD complains that the connection to the FLARM device has been lost.
I guess, the iPad loses the WLAN connection when sleeping which causes the above problem.
Did someone else ffind this problem or has a solution for this?
If there is no good solution, I would love to see a kind of recovery-mechanism in the next SD-version.
I am thinking of a mechanism which keeps trying‌‌‌ to (re)connect to the FLARm device (or anything else) even when the WLAN-connection has been lost and or restored.
We could re-engineer our FLARM connectivity code as you suggest, but we wouldn't touch it without a very good reason, which would be that many people are suffering a disconnection problem. The problem in this case appears to be self-inflicted as you are purposely closing the lid on your device which suspends all apps and terminates any network connections.
Europa XS
Europa XS
Posts: 22, Visits: 215
Tim Dawson - 6/21/2018 2:39:01 PM
I read your answer with great interest because I regain the hope that the connection problems between SD and PF can finally be solved.‌ I do not use an IPad but an Android device (HUAWEI Multimedia Pad 3) and had nearly at every flight the problem with a lost WIFI connection between SD and PF (mostly after around 20 - 30 min flight time). In my case it was not a problem with any flip case or similar, because I do not use that. At the moment I use the local services of the tablet and an external display for the FLARM traffic. I am not alone with this strange behavior between SD and PF, at least 3 other colleagues in my club have the same problems. So please consider this as a functionality of SD with room for improvement.
Kind regards
Europa XS‌‌
drnicolas - 5/21/2018 6:29:59 PM
Grila - 5/29/2018 5:43:38 PM
drnicolas - 5/30/2018 8:41:11 AM
efrenken - 5/30/2018 7:32:34 PM
Tim Dawson - 6/21/2018 9:34:03 AM
drnicolas - 6/21/2018 10:08:39 AM
Europa XS - 6/22/2018 8:06:30 AM
Tim Dawson - 6/25/2018 9:21:30 AM
Europa XS - 6/26/2018 12:43:03 PM
Tim Dawson - 6/27/2018 11:08:57 AM
Grila - 8/25/2018 6:23:30 PM
ken@blackman.co.uk - 12/8/2018 12:15:20 PM
Grila - 12/20/2018 9:17:13 PM
Fliegerpeer - 1/31/2019 3:57:39 PM
Aslak - 8/9/2019 4:36:17 PM
Grila - 8/19/2019 3:10:26 PM
