rikur
rikur
Posts: 132, Visits: 632
SemperFi - 11/1/2017 7:44:00 AM
rikur - 10/31/2017 1:22:28 PM
If you are having problems running on MacOS High Sierra, download the latest version from the first page of this thread, which contains some tweaks to avoid some known issues on High Sierra.
Link is not working actually?
apologies - fixed now
CaptRouge
CaptRouge
Too Much Forum (383 reputation)Too Much Forum (383 reputation)Too Much Forum (383 reputation)Too Much Forum (383 reputation)Too Much Forum (383 reputation)Too Much Forum (383 reputation)Too Much Forum (383 reputation)Too Much Forum (383 reputation)Too Much Forum (383 reputation)
Posts: 5, Visits: 4
Works Just fine,
‌PS never had a problem before with map updates either. Only problem was it didn't fill the screen but that was easily resolved by minimising and then maximising.
‌Wineskin is fabulous and have used it on other Applications and always seems to work perfectly as long as you follow the steps carefully.
Capt. Vin Rouge
EGBD & LFMZ
nhodgson
nhodgson
Too Much Forum (577 reputation)Too Much Forum (577 reputation)Too Much Forum (577 reputation)Too Much Forum (577 reputation)Too Much Forum (577 reputation)Too Much Forum (577 reputation)Too Much Forum (577 reputation)Too Much Forum (577 reputation)Too Much Forum (577 reputation)
Posts: 3, Visits: 41
Hi, just started using on my MAC - when minimised to the dock SkyD will not re-launch and has to be killed via Force Quit and restarted from Applications. Is this a known problem? Using OSX 10.13.2 High Sierra on MacBook Air. Thanks and thanks for creating SkyD on a MAC!
rikur
rikur
Unfortunately, yes, this seems to be a Wineskin bug in High Sierra.
There is sort of a work around .... if you select SkyDemon from the dock, somewhere on the screen you should see a small title bar saying "SkyDemon Plan" .... if you double click on this, it should restore the window .... see example:
OmeRon
O
Too Much Forum (57 reputation)Too Much Forum (57 reputation)Too Much Forum (57 reputation)Too Much Forum (57 reputation)Too Much Forum (57 reputation)Too Much Forum (57 reputation)Too Much Forum (57 reputation)Too Much Forum (57 reputation)Too Much Forum (57 reputation)
Posts: 1, Visits: 1
When I'm trying to print off a briefing pack, I get this error in the MACOS print center:
Printing - ERROR:/.SFCompactDisplay-Heavy‌‌‌
rikur
rikur
OmeRon - 1/2/2018 1:14:16 PM
I seemed to be able to recreate this temporarily, but them subsequent attempts to print have been ok
S‌o a little confused, I think it is something to do with fonts - but can't do much more investigation until I can recreate it again.
Alan Wilkinson
Alan Wilkinson
Too Much Forum (402 reputation)Too Much Forum (402 reputation)Too Much Forum (402 reputation)Too Much Forum (402 reputation)Too Much Forum (402 reputation)Too Much Forum (402 reputation)Too Much Forum (402 reputation)Too Much Forum (402 reputation)Too Much Forum (402 reputation)
Posts: 4, Visits: 0
Im getting an error message "cannot write to info.plist file" Can anyone assist?
rikur
rikur
Alan Wilkinson
Alan Wilkinson
Posts: 4, Visits: 0
rikur - 2/21/2018 10:11:26 AM
Much appreciated! Working now.
G-OIBM
G-OIBM
Posts: 71, Visits: 946
I managed to install SkyDemon on my MacBook Pro - and it worked first time :-)
A‌ quick question though - the fonts and graphics look very grainy and looks like an old windows screen when the resolution wasn't quite correct.  Is this a setting on my MacBook Pro that is wrong or a limitation of the emulation skin software?
T‌his is not a moan, and I must thank the developer for all the hard work done so far.‌‌
Hugh
G-OIBM
Commander 114
