+xG-OIBM - 3/17/2018 12:18:31 PMI managed to install SkyDemon on my MacBook Pro - and it worked first time :-)A quick question though - the fonts and graphics look very grainy and looks like an old windows screen when the resolution wasn't quite correct. Is this a setting on my MacBook Pro that is wrong or a limitation of the emulation skin software?This is not a moan, and I must thank the developer for all the hard work done so far.
+xandydavy - 5/22/2018 8:34:16 PMHiI downloaded & installed the Mac version again (yes, I deleted the previous one from the Applications folder) and I keep getting SkyDemon.exe crashes (immediately after startup). Any clues?
mv "$HOME/library/application support/Divelements Limited" "$HOME/library/application support/Divelements old"mv "$HOME/documents/SkyDemon" "$HOME/documents/SkyDemon old"
+xandydavy - 5/26/2018 11:37:17 AMMore on this. I have tried this with version 3.8.2.0 & 3.7.1 & get similar results when following the above steps.At first I thought it followed updating the charts, but that's not the case.I have tried this on two different Macs, with the same results. The second had never had SkyDemon installed on it.A pity, as it has rendered SkyDemon unusable for me.
+xSemperFi - 7/1/2018 3:31:38 PMSame crashes here - current Skydemon Plan @macOS is INOP ...
