Virtual Radar situational awareness not sufficient
Gerhard66
G
Posts: 168, Visits: 355
I'm absolutely missing a function to set horizontal and vertical scale for virtual radar!
The automatic zoom is by far not sufficient for many situations in the alps.
When crossing the alps, you often cannot fly the planned route due to cloud conditions.
After crossing the alps N->S i.e. in 12000 ft, typically a descent down to 1000 ft follows.
This area is crowded with military airspace, class D airspaces and controlzones of different airports.
Parts of the planning becomes useless and you have to do some ad hoc planning in flight in a complicated airspace structure.
But SD lets me look ahead only a few minutes, which is not enough for a 11000 ft standard descent.
Similar situations can occur during climb to higher altitudes.
efrenken
efrenken
Posts: 265, Visits: 3.5K
Ok, which means of communication do you consider inside your normal support channels?
Why don't you ask the forum community to change over to normal support channels?
Edited 6/27/2017 6:54:28 PM by efrenken
