wb8
Visits: 20
+x+xI have just posted a beta version on our beta page. I'd appreciate it if you could install it and let me know whether there is any change. Thanks! Hi all, First of all: I really love SkyDemon. A lot of useful features for proper VFR flight planning. Great job! However, I just bought an Android Tablet Z3 Compact and realized 3 issues. One of them is that loading embedded charts take really some time. 25 seconds for an arrival chart is really long. I am not sure if this normal or also the beforementioned topic that the Android app became very slow. I created a video for this (below). I have also realized that I see issue #1 and #2 is also existing on Samsung Galaxy S7. I tried to use the latest beta 3.7.1xx, but it crashes after a couple of seconds. Version: 3.7.0.27593 Hardware: Sony Z3 Compact Tablet Issue #1: Embedded Charts loading takes very long time (EDDL Arrival Chart takes 25 seconds!) Issue #2: Map jumps around when zooming. In the video, I have zoomed Wuppertal, but suddenly the map moves to the left to Düsseldorf Wolfsaap. Very nasty in flight. (I found out that it always zooms into the center of the map. That's why I thought it was jumping. So forget about #2 as an issue. Although it is not very convenient, but I will get used to it). Issue #3: Strange Approach Charts (here: EDDL DFS Approach Chart). But this happens very seldomly. My question: Is this a temporary topic? Reason for asking: I might want to send the device back to amazon and get myself an ipad mini instead, if these performance issues don't show up on Apple devices. Kind regards and a happy new year, Nazze I experience the same issue on both android devices: Samsung galaxy Tab S2 (android 7.0) LG Nexus 5x (android 7.1.2) Both are running SkyDemon 3.8.1.18190. Both are using the stock- android rom. Both need a long time to load vfr-plates. Both of them are unable to provide a steady zoom-in/out behaviour (the two-finger zoom won't zoom-in and zoom-out as expected and the preview of the zoom does not match the result). As soon as both fingertips are released from the screen, skydemon jumps to a different area in the surrounding of the previous screen. The behaviour is getting worse, when both fingertips are moved to the left or the right during spreading away from each other. I'm not a 100%sure, but I think the whole behaviour is a little bit improved by disabling the live data in planning-mode. To load the VFR chart of LOAV takes - ~12 seconds on the galaxy tab S2 - ~25 seconds on the Nexus 5x The galaxy tab is my primary device so I can live with the issues on the mobile phone but the performance issues on the galaxy tab should be fixed. If required I can provide videos too.
crablab
Visits: 1
I have this problem on a Nexus 6 running Android 7.1.1. Interestingly, I don't have an issue on my Neuxs 9 which is running the same release.
Does that help?
macht_rebel
Visits: 37
+x[quote] Hi Nazze, I fully agree with Eric. It is fast and reliable. Best, Marc
efrenken
Visits: 3.5K
Nazze,
My recommendation: Send the tablet back and get an iPad.
I enjoy flying with iPad and SD now in my 3rd or 4th year and never had any problems.
Eric
Nazze
Visits: 3
Posts: 7.8K,
Visits: 8.5K
Visits: 2.3K
Understand. Well my device, as mentioned, is a standard Samsung S3 Galaxy. Probably nearly 3 years old now. Yes, I know that is old now........ I think other users with similar performance issues are using other devices.
Tony
Posts: 7.8K,
Visits: 8.5K
That is something we may need to resort to, but it's undesirable as we could be producing a great deal of releases trying to narrow down the problem. Also, you will not be able to see debug output. We will probably end up buying a device so we can try and reproduce it ourselves, but we want to be sure the device we buy will demonstrate the problem before we do that.
Visits: 2.3K
+xIf anybody has an Android device on which SkyDemon has recently slowed down (since the 3.6.2 version) so much as to be unusable, you are welcome to lend us the device if you're happy for us to try to debug the problem. Meanwhile we will continue trying to see what might be the problem here, but it's difficult because so few devices appear to be affected and we're unable to reproduce the problem here. I was going to lend you my Nexus 7 (Android 5.1.1) but SD 3.6.5.26060 appears to run okay (on the ground). No obvious slow performance issues. However my primary SD device is my smartphone (Samsung Galaxy S3) and that does exhibit the problem. As it is also my mobile phone I can't lend it to you but wondered if I can test various test releases of SD software on it to try and help you pin down the issue? You obviously know what changes have been made between 3.6.2 and 3.6.3 so perhaps you can create "test versions" to tests the various code changes? Tony
Posts: 7.8K,
Visits: 8.5K
