MikeTwoOne
MikeTwoOne
Posts: 147, Visits: 2.1K
That's great news!
Knowing you're also reproducing the issue is a big step forward.
In the meantime, here are some logs from today's beta.
M
Mike@EDTG
Mike@EDTG
Posts: 164, Visits: 757
Simulation mode doesn't work anymore with the may 7th beta & a silent crash now and then when approaching the weather menu.
mike
srayne
srayne
Posts: 388, Visits: 8.3K
Simulation mode broken for me too.
Simulate mode is broken on purpose. We probably should have undone that before releasing the beta, sorry about that. It's designed to stress SkyDemon into reproducing the crash that some people are experiencing on their devices.
There will be a new beta later today. Results of tests over the weekend indicate that we have now identified and fixed the most common cause of instability within SkyDemon for Android, so we will be interested to hear your feedback.
The simulate feature will probably still be intentionally broken in today's beta.
MikeTwoOne
MikeTwoOne
Today's beta is definitely a big step forward. SD is way more robust.
Unfortunately, I have a crash log to share.
Note that it happened after a quite long test session, using the "simulation roller coaster mode" for 80 minutes!
Before, I was able to generate a crash in less than 2 minutes.
M
3.0.7.26675.txt (1.6K views, 10.00 KB)
srayne
srayne
MikeTwoOne (13/05/2014)Hi,Today's beta is definitely a big step forward. SD is way more robust.Unfortunately, I have a crash log to share.
Mike,
How do you get hold of your crash logs - have you rooted your device?
Simon
Edited 5/13/2014 8:49:12 AM by srayne
MikeTwoOne
MikeTwoOne
No root. I've installed the Android SDK, and, when connecting my devices to my computer, I'm able to access the logs using Android Device Monitor.
With SD not generating this "report popup" we're missing so much, this is the less difficult way to contribute crash logs.
M
Thanks, that is good news. It seems we may have eliminated by far the most common cause of instability, the one which all your previous logs were pointing to.
This is a new one, and it's not one we've ever seen before. In fact looking at the code, it's "impossible" which may be as a result of memory corruption. Would you mind running a couple more tests to see what the results are?
I'm still looking into why we're not getting a helpful popup.
MikeTwoOne
MikeTwoOne
I'll do some extensive testing this evening Smile
