Crash on Android 4.4.2 / SD 3.0.3
srayne
srayne
Posts: 388, Visits: 8.3K
Thanks Mike for the info, I'll try that.
Tim,
I have been testing the Android beta (12th May) and also find it much more reliable - no more silent crashes yet. However, if left running on my Nexus 7 with the 'debug' simulation then on two occasions (once after 1hour and again after 1hr40mn) SkyDemon just locks up (fixed display and unresponsive to presses). Both times I have had to manually kill SkyDemon and have thus not got a debug log yet. I'll keep trying.
Simon
MikeTwoOne
MikeTwoOne
Posts: 147, Visits: 2.1K
After some hours (around 7 ...) of testing since yesterday:
- I haven't been able to reproduce any crash, whish is great!
- SD regularly freeze after 60/90 minutes. Perhaps it's a side effect of the broken simulation mode.
When touching the screen after a freeze, Android allows me to kill it but it does not generate interesting logs, I'm afraid.
Anyway, they're attached, as always Smile
M
3.0.7.26675_2.txt (1.6K views, 8.00 KB)
3.0.7.26675_3.txt (1.7K views, 2.00 KB)
sweetpot
sweetpot
Posts: 18, Visits: 243
I didn't have a crash yet in the planning mode with the new beta, but I got one in simulated mode when recording the flight ( in less than 10min) and another in the car when recording "the flight".
When I do not record the flight I had no problem.
Edit: I tried again the simulated mode recording the flight without crashes for more than a hour.
Simulated mode freeze for me too.
So it is much beter but not perfect yet.
Edited 5/14/2014 7:01:02 PM by sweetpot
alberto
alberto
Posts: 20, Visits: 291
Does anybody know the features of the new beta (27.05.2014)?
There is only one Android feature change in the latest beta:
You can now open routes directly from email attachments (Android)
The rest is minor continued work on stability.
Pete
Pete
Posts: 129, Visits: 966
Latest android beta(27th May) seems to work well,......no cloning of waypoints,....... no silent crashes(so far), can't see the email route feature- but not an issue.
Thank you-excellent!
Edit: one silent crash so far on start up: 2 hrs flying
Edited 6/3/2014 11:59:28 PM by Pete
MikeTwoOne
MikeTwoOne
I'm afraid crashs are back with 3.0.7.16856.
Log is attached.
M
log.3.0.7.16856.txt (1.8K views, 3.00 KB)
No, that crash is different to the one which was causing stability problems across a few devices and certainly isn't something introduced in the latest beta. It reads like a memory corruption issue; extremely rare and unfortunately beyond our control I'm afraid. The common crash in all the original logs you sent to us is definitely solved and should not come back.
sweetpot
sweetpot
Unfortunately, I got two crashes with the last beta.
Both of them in flying mode.
The first one after 30 min. when trying the new beta in my car.
The second one during a touch and go in a piper cub this Sunday after 50 min.
So in less than two hours of test I got two crashes...
I didn't encounter any crash in planning mode with this beta.
Edited 6/4/2014 7:55:16 PM by sweetpot
sweetpot
sweetpot
I just upgraded to android 4.4.3, I will test tomorrow if it change something.
