Using iPad SkyDemon Navigation with FSX
X-Plane connectivity was introduced in SkyDemon 3.0.4.
OscarTango
OscarTango
Too Much Forum (382 reputation)Too Much Forum (382 reputation)Too Much Forum (382 reputation)Too Much Forum (382 reputation)Too Much Forum (382 reputation)Too Much Forum (382 reputation)Too Much Forum (382 reputation)Too Much Forum (382 reputation)Too Much Forum (382 reputation)
Posts: 2, Visits: 5
Hi all,
I've installed FlightsimGPS, and have Skydemon version 3.0.5 on an Ipad 2.... I start FlightsimGPS, then FSX, load a flight, and then start Skydemon on the iPad. As soon as I go into connectivity and select X-plane, the app crashes.
How/where do I extract a crashlog for someone to review ?
Tim Opdencamp
new user :-)
This is probably a known problem whereby the simulator sends nonsense data, which crashes the current public version of SkyDemon. The forthcoming update detects and ignores the specific nonsense data, so it would probably be worth waiting for that.
Biggles-EGKB
Biggles-EGKB
Posts: 51, Visits: 417
Hi
I'm running the iPad SD version with FS2002 & 2004 without any issues and find this an excellent training aid.
Using FSUIPC.DLL with the FlightSimGPS links seamlessly with the iPad X-Plane Connectivity Option and the whole setup is FREE!!!!
Just a thought
Biggles
Biggles -- EGKB
OscarTango
OscarTango
Posts: 2, Visits: 5
Tim Dawson (22/04/2014)
Heyhey, I donwloaded the new version, and it still did it ( crashing ), but then I read the other post on this topic, and changed the decimal comma to a point in Windows and now it works.Thought I'd share.... people in Belgium, Netherlands,...might find it usefull.
Right...off to FSX I go :-)
Mike@EDTG
Mike@EDTG
Posts: 164, Visits: 757
´same problem here. My workaround - change the Windows Area Setting to US - start FlightsimGPS - change back to DE & everything works smooth on my
Asus HD7
-mike
col-lucy
col-lucy
Posts: 19, Visits: 170
Hi all,
I put an installer for a small program (Fsx2Skydemon) that receives data from FSX, and forwards it to SkyDemon using the x-plane protocol (supported by newer versions of Skydemon).
The link is here:
https://onedrive.live.com/redir?resid=62A857FB93775AA!9796&authkey=!ADlwSTS_uOYVfQs&ithint=file%2c.zip
Install it on the same PC as your FSX, and run it when you start FSX
Configure Fsx2Skydemon with the IP address of your iPad or Android tablet.
Start Skydemon on your tablet and set it to use x-plane input.
There is a little help document to assist with setup.
Colin
Tags
Mike@EDTG
Mike@EDTG
Hi colin,
any chance do make it working for FS9?
mike@edtg
Edited 6/7/2014 8:32:13 AM by Mike@EDTG
Francoisvl
Francoisvl
Posts: 7, Visits: 26
Hi there - I set this up and can see that the app is receiving data from FSX, and 'transmitting to SD' but SD never picks it up. I've set the IP address to the one on the wifi connection on my iPad - but not sure where you get info on the ports - could this be the problem?
Kind regards
Francois
Francoisvl
Francoisvl
I did get this to work immediately, but the data going to SD seems to have lots of direction changes/spikes so that the experience is not very smooth - ie, the SD track changes direction often and jumps around a lot. Anyone else have this, or know how to smooth the data going to SD? I seem to lose connection intermittently too.
Francois
