Visits: 166
Hi all,
I'm not sure about making it work with FS9. I don't even have a copy to test with. I'm sure the SimConnect dll will be different for FS9. Sorry.
If you are receiving & transmitting data to Skydemon, then it is probably an IP address or port problem. SD receives on port 49002. Set that in 'OutPort', and set 'LocalPort' to something else
You can get the iPad's IP address from Settings/WiFi. Select The 'i' for the connected network shows the IP address. Enter this into 'OutAddr' in settings. Assuming your iPad is on the same network as your Flight Sim PC, it ought to work. Bear in mind that Fsx2Skydemon only sends data when the aircraft is in motion. If its paused or parked, you will get no data. Note that the IP address could change from session to session.
I have no idea why the updates would be jerky and changing direction. The track will reset if there is a large jump in position (e.g. you load a new scenario). The corresponds to about Mach 1, so should not be a problem. Does the Data LED flash regularly, or is it erratic?
Cheers
Colin
