Charts and Aeronautical Data
Kleine Brogel Airbase missing on Belgium map EBBL
Henny Joosten
Henny Joosten
posted 3/12/2014 9:31:18 AM
Visits: 349
Hello Tim,
On the Belgium map,
BBL tacan is displayed but the EBBL airbase is not.
If I try to find it (find waypoint) it's found in Skydemon but there is no icon of the airbase.
Regards,
Henny
12/3/2014
Tags
EBBL MAP
posted 3/13/2014 8:10:43 AM
Visits: 2.2K
Check the setting which filters displayed airports according to runway length etc. Almost certainly the problem can be found there.
Henny Joosten
Henny Joosten
posted 3/13/2014 3:08:54 PM
Visits: 349
Hello Chris,
No, all runways above 500 meters are displayed. Im nearly shure its a technical map issue. Thanks for the reply! Regards, Henny.
Tags
ebbl
map
efrenken
efrenken
posted 3/13/2014 10:25:55 PM
Visits: 3.5K
I just checked it. It is shown on my map, but without any rwy.
Eric
Tags
Ebbl
Henny Joosten
Henny Joosten
posted 3/14/2014 9:20:04 AM
Visits: 349
Thanks Eric.
I hope Skydemon will check it.
Regards,
Henny.
posted 3/14/2014 3:51:57 PM
Posts: 8.3K,
Visits: 10K
Chris is correct, the airfield is present. We have no runway data for it, so if you enforce a minimum runway length it will not be shown. Please remove this filtering setting if you want to see it.
Henny Joosten
Henny Joosten
posted 3/16/2014 8:22:32 AM
Visits: 349
Solved. Thanks for the solution.
Regards Henny
Henny Joosten
Henny Joosten
posted 3/28/2014 12:41:52 PM
Visits: 349
Hello Tim,
From the Belgium AIP the (rwy) info about the (missing) military airport Kleine Brogel Belgium EBBL.
Regards,
Henny
1.3K views,
32.00 KB
Tags
AIP Belgium
EBBL
posted 3/28/2014 5:13:03 PM
Posts: 8.3K,
Visits: 10K
Thanks, we have actually already ensured this will be present in the next Belgium chart update.
