Kleine Brogel Airbase missing on Belgium map EBBL
Henny Joosten
Henny Joosten
Posts: 48, Visits: 349
Hello Tim,
On the Belgium map, BBL tacan is displayed but the EBBL airbase is not.
If I try to find it (find waypoint) it's found in Skydemon but there is no icon of the airbase.
Regards,
Henny
12/3/2014
Tags
Check the setting which filters displayed airports according to runway length etc. Almost certainly the problem can be found there.
Henny Joosten
Henny Joosten
Hello Chris,
No, all runways above 500 meters are displayed. Im nearly shure its a technical map issue. Thanks for the reply! Regards, Henny. Smile
Tags
efrenken
efrenken
Posts: 265, Visits: 3.5K
I just checked it. It is shown on my map, but without any rwy.
Eric
Tags
Henny Joosten
Henny Joosten
Thanks Eric.
I hope Skydemon will check it.
Regards,
Henny.
Chris is correct, the airfield is present. We have no runway data for it, so if you enforce a minimum runway length it will not be shown. Please remove this filtering setting if you want to see it.
Henny Joosten
Henny Joosten
Solved. Thanks for the solution.
Regards Henny
Henny Joosten
Henny Joosten
Hello Tim,
From the Belgium AIP the (rwy) info about the (missing) military airport Kleine Brogel Belgium EBBL.
Regards,
Henny
ebbl aerodrome info aip belgium.gif (1.3K views, 32.00 KB)
Thanks, we have actually already ensured this will be present in the next Belgium chart update.
