Flightplan route waypoints
bharb
bharb
Posts: 26, Visits: 351
Hello!
When filing a flightplan the route is filled by waypoints represented as coordinates. Would it be possible to change this, so that the names of the waypoints are shown like in the PLOG?
Thanks,
Bernhard.
Significant points with designators can only be used in the route field because they are clearly defined in AIP ENR 4.x.
Although many four-letter airfield designators are defined in AIP AD, there are a huge number of these in many countries which are NOT defined in the AIP (except the location decode section). The positions of them are simply undefined, therefore any recipient of the flightplan performing machine reading of the plan (this is the critical part) would fail if such a designator were used.
As somebody else mentioned, the primary recipient of flightplans in Europe in Eurocontrol. If you attempt to put an airfield ICAO identifier in your route plan in such a flightplan, it will rightly be rejected.
Tim, how often have you tried putting an airport ID in the route field of a flight plan? I have done it myself many times (VFR mainly but also IFR). They were all flightplans addresssed to Eurocontrol. None of them has been rejected for this reason yet.
Have you talked to an actual live controller about this? I have, several times to different controllers (wherever the opportunity arose in the past 1-2 years). None of them have told me otherwise. In fact, they all confirmed that they prefer published names over coordinates.
lhe
lhe
Posts: 154, Visits: 445
I did that before posting my previous message. The flight plan was rejected.
This was the flight plan:
(FPL-SEMBN-IG
-C172/L-SDFGY/S
-ESKC2000
-N0104A025 DCT ESOW DCT
-ESSB0050 ESSA
-DOF/140201 ORGN/ESSAZPZX
-E/0300 P/1 R/E A/W)
...and this was the reply error message: "ERROR ROUTE130: UNKNOWN DESIGNATOR ESOW"
When I replaced "ESOW" with the id of a proper significant point the flight plan was accepted. (Well, of course I had to choose one which would form an acceptable route, but that is another matter...)
(And yes, ESOW is a proper airport. Scheduled services and all.)
Very interesting indeed. I tried to access international flightplans of mine from last year off the homebriefing server but they weren't accessible anymore. However, the next one I file I'll post here just to prove that I wasn't dreaming. The only difference I can see is that mine didn't have the DCT acronym inserted in the route section. But I think it's doubtful this would make a difference.
Edited 2/7/2014 12:33:41 PM by ckurz7000
lhe
lhe
You must use DCT or a route designator for each segment of the route (except when you use geographical coordinates), otherwise the flight plan will again be rejected.
If you say that you have successfully submitted IFR flight plans using location indicators in the route section and without using DCT, then I suspect that your homebriefing provider corrected the flight plan (manually?) before being sending it on to the IFPS.
I was using the Swedish CAA flight plan submission system which sends IFR flight plans straight to the IFPS. VFR flight plans are sent to a briefing officer for manual checking and they can fix obvious errors such as omitting DCT. (Although one time when I submitted two VFR flight plans in succession with the same obvious error, they corrected the first one silently but called me to complain about the second one.)
Btw: I've never understood why DCT is required. There can be no ambiguity if you omit it and there would be less to write...
srayne
srayne
Posts: 388, Visits: 8.3K
lhe (07/02/2014)I've never understood why DCT is required. There can be no ambiguity if you omit it and there would be less to write...
An IFR route would normally be a list of significant points separated by ATS route designators, the DCT is use to replace the route designator where there is none (as in a VFR flight) this makes parsing easier.
Edited 2/7/2014 2:31:57 PM by srayne
lhe
lhe
The added difficulty of parsing a route description without DCT would be negligible. (At least as long as it is impossible for an ATS route and a significant point to have the same designator.)
bharb - 1/25/2014 10:09:06 PM
ckurz7000 - 1/26/2014 2:59:28 PM
bharb - 1/27/2014 10:15:51 AM
bharb - 1/27/2014 1:13:58 PM
ckurz7000 - 1/27/2014 4:07:30 PM
lhe - 1/29/2014 1:42:00 PM
Tim Dawson - 1/29/2014 5:05:09 PM
bharb - 1/30/2014 3:24:03 PM
ckurz7000 - 1/31/2014 2:35:18 PM
lhe - 2/1/2014 4:51:00 PM
srayne - 2/1/2014 5:37:38 PM
ckurz7000 - 2/2/2014 8:44:41 PM
srayne - 2/3/2014 8:47:24 AM
                     I read the relevant portion of CAP 694. It says to use only...
ckurz7000 - 2/3/2014 10:21:18 AM
Tim Dawson - 2/4/2014 5:29:29 PM
ckurz7000 - 2/6/2014 3:23:16 PM
lhe - 2/6/2014 7:39:04 PM
ckurz7000 - 2/7/2014 12:32:05 PM
                         You must use DCT or a route designator for each segment of the route...
lhe - 2/7/2014 1:53:03 PM
                             [quote][b]lhe (07/02/2014)[/b] I've never understood why DCT is...
srayne - 2/7/2014 2:30:33 PM
                                 The added difficulty of parsing a route description without DCT would...
lhe - 2/7/2014 4:25:11 PM
Tim Dawson - 2/6/2014 3:43:25 PM
Tim Dawson - 3/20/2014 1:09:01 PM
ckurz7000 - 3/20/2014 3:42:09 PM
Tim Dawson - 3/20/2014 5:09:01 PM
ckurz7000 - 3/20/2014 8:07:20 PM
Tim Dawson - 3/21/2014 10:23:16 AM
bharb - 3/21/2014 1:54:28 PM
Tim Dawson - 3/21/2014 4:09:23 PM
bharb - 3/22/2014 8:32:54 AM
