Flightplan route waypoints
bharb
bharb
Posts: 26, Visits: 351
Hello!
When filing a flightplan the route is filled by waypoints represented as coordinates. Would it be possible to change this, so that the names of the waypoints are shown like in the PLOG?
Thanks,
Bernhard.
lhe
lhe
Posts: 154, Visits: 445
You must use DCT or a route designator for each segment of the route (except when you use geographical coordinates), otherwise the flight plan will again be rejected.
If you say that you have successfully submitted IFR flight plans using location indicators in the route section and without using DCT, then I suspect that your homebriefing provider corrected the flight plan (manually?) before being sending it on to the IFPS.
I was using the Swedish CAA flight plan submission system which sends IFR flight plans straight to the IFPS. VFR flight plans are sent to a briefing officer for manual checking and they can fix obvious errors such as omitting DCT. (Although one time when I submitted two VFR flight plans in succession with the same obvious error, they corrected the first one silently but called me to complain about the second one.)
Btw: I've never understood why DCT is required. There can be no ambiguity if you omit it and there would be less to write...
srayne
srayne
Posts: 388, Visits: 8.3K
lhe (07/02/2014)I've never understood why DCT is required. There can be no ambiguity if you omit it and there would be less to write...
An IFR route would normally be a list of significant points separated by ATS route designators, the DCT is use to replace the route designator where there is none (as in a VFR flight) this makes parsing easier.
Edited 2/7/2014 2:31:57 PM by srayne
lhe
lhe
The added difficulty of parsing a route description without DCT would be negligible. (At least as long as it is impossible for an ATS route and a significant point to have the same designator.)
bharb - 1/25/2014 10:09:06 PM
ckurz7000 - 1/26/2014 2:59:28 PM
bharb - 1/27/2014 10:15:51 AM
bharb - 1/27/2014 1:13:58 PM
ckurz7000 - 1/27/2014 4:07:30 PM
lhe - 1/29/2014 1:42:00 PM
Tim Dawson - 1/29/2014 5:05:09 PM
bharb - 1/30/2014 3:24:03 PM
ckurz7000 - 1/31/2014 2:35:18 PM
lhe - 2/1/2014 4:51:00 PM
srayne - 2/1/2014 5:37:38 PM
ckurz7000 - 2/2/2014 8:44:41 PM
srayne - 2/3/2014 8:47:24 AM
                     I read the relevant portion of CAP 694. It says to use only...
ckurz7000 - 2/3/2014 10:21:18 AM
Tim Dawson - 2/4/2014 5:29:29 PM
ckurz7000 - 2/6/2014 3:23:16 PM
lhe - 2/6/2014 7:39:04 PM
ckurz7000 - 2/7/2014 12:32:05 PM
                         You must use DCT or a route designator for each segment of the route...
lhe - 2/7/2014 1:53:03 PM
                             [quote][b]lhe (07/02/2014)[/b] I've never understood why DCT is...
srayne - 2/7/2014 2:30:33 PM
                                 The added difficulty of parsing a route description without DCT would...
lhe - 2/7/2014 4:25:11 PM
Tim Dawson - 2/6/2014 3:43:25 PM
Tim Dawson - 3/20/2014 1:09:01 PM
ckurz7000 - 3/20/2014 3:42:09 PM
Tim Dawson - 3/20/2014 5:09:01 PM
ckurz7000 - 3/20/2014 8:07:20 PM
Tim Dawson - 3/21/2014 10:23:16 AM
bharb - 3/21/2014 1:54:28 PM
Tim Dawson - 3/21/2014 4:09:23 PM
bharb - 3/22/2014 8:32:54 AM
