SkyDemon Flight Planning
Flightplan route waypoints
bharb
bharb
posted 1/25/2014 10:09:06 PM
HOT
Visits: 351
Hello!
When filing a flightplan the route is filled by waypoints represented as coordinates. Would it be possible to change this, so that the names of the waypoints are shown like in the PLOG?
Thanks,
Bernhard.
bharb
Hi Bernhard, this request has been made a number of times. Tim claims...
1/26/2014 2:59:28 PM
Hello! Thanks for the reply. Maybe an option would be fine, in...
bharb
1/27/2014 10:15:51 AM
Hello again! I just had a quick talk to one of Austrocontrol's...
bharb
1/27/2014 1:13:58 PM
Servus Bernhard, you better do a search of the forum to locate the...
1/27/2014 4:07:30 PM
[quote] I have included ICAO rules and guidelines which definitely say...
lhe
1/29/2014 1:42:00 PM
There are only a limited number of things that can be used in field 15...
1/29/2014 5:05:09 PM
@lhe: That maybe correct, but there are different rules in different...
bharb
1/30/2014 3:24:03 PM
ICAO, in fact, requests the NAME of a significant point if there is...
1/31/2014 2:35:18 PM
[quote]Therefore airport IDs are perfectly fine, and you'd draw some...
lhe
2/1/2014 4:51:00 PM
According to the following no airport identifiers or placenames are...
srayne
2/1/2014 5:37:38 PM
I fail to see where in your citation it says that you shouldn't use...
2/2/2014 8:44:41 PM
[quote][b]ckurz7000 (02/02/2014)[/b][hr]I fail to see where in your...
srayne
2/3/2014 8:47:24 AM
I read the relevant portion of CAP 694. It says to use only...
2/3/2014 10:21:18 AM
Significant points with designators can only be used in the route...
2/4/2014 5:29:29 PM
Tim, how often have you tried putting an airport ID in the route field...
2/6/2014 3:23:16 PM
[quote]Tim, how often have you tried putting an airport ID in the...
lhe
2/6/2014 7:39:04 PM
Very interesting indeed. I tried to access international flightplans...
2/7/2014 12:32:05 PM
You must use DCT or a route designator for each segment of the route...
lhe
2/7/2014 1:53:03 PM
[quote][b]lhe (07/02/2014)[/b] I've never understood why DCT is...
srayne
2/7/2014 2:30:33 PM
The added difficulty of parsing a route description without DCT would...
lhe
2/7/2014 4:25:11 PM
Yes, I have consulted many live controllers at NATS and other...
2/6/2014 3:43:25 PM
I think we may have a potential solution to this, where some VRPs are...
3/20/2014 1:09:01 PM
Here is the excerpt from Austro Control regarding specification of...
3/20/2014 3:42:09 PM
Can you give an example of some VRPs in Austria which meet that...
3/20/2014 5:09:01 PM
For example the points STEIN, PESAT and SASAL. They are coordination...
3/20/2014 8:07:20 PM
Those are not VRPs and would never have been converted to coordinates...
3/21/2014 10:23:16 AM
Just a two examples of what has been accepted in Austria on my last...
bharb
3/21/2014 1:54:28 PM
Thanks, it's only VRPs we are working with at the moment however....
3/21/2014 4:09:23 PM
Great news, thanks in advance. K is in the north of Linz (LOWL) at...
bharb
3/22/2014 8:32:54 AM
