Missing VRPs/VACs
lhe
lhe
Posts: 154, Visits: 445
They are not actually reporting points, but they are waypoints on the VFR routes (ref. AIP SWEDEN AD 2 ESSB 6-3/4).
If you e.g. enter Bromma CTR at ÄLVNÄS for landing RWY 30, you usually get an initial clearance to BJÖRNHOLMEN. A direct track would take you through restricted area ES R 24. You should route via KUNGSHATT. The same goes for departures RWY 12, exiting the CTR at ÄLVNÄS.
But ok, if you don't have "official" coordinates from the AIP, I can see why you might be reluctant to put them in the Skydemon database. It is certainly not a big deal for me to enter them as user waypoints.
I am informed that RINKEBY and KUNGSHATT are not actually VRPs and that is why they are not included in our data; there are no official GPS coordinates published for them.
Nittedal is a VRP for ENKJ, not ENGM, and it appears to be valid.
Thank you, I will pass the VRP feedback on to the appropriate people. Unfortunately the document entitled simply "ENGM 6-3" has no hint in its title that it is in fact a VAC and therefore is overlooked by our system.
lhe
lhe
The VRPs RINKEBY and KUNGSHATT for ESSB are missing from the Skydemon database. They are important as they are waypoints on standard VFR ARR/DEP routes. (Ref. AIP-SWEDEN AD 2 ESSB 6-3 and 6-4).
Downloadable plates for ENGM doesn't include AIP-NORWAY AD 2 ENGM 6-3 which is the VAC for ENGM. Also the VRP NITTEDAL for ENGM which appears on Skydemon's chart appears to have been withdrawn.
