Missing VRPs/VACs
http://forums.skydemon.aero/Topic9063.aspx
By lhe - 4/26/2013 8:35:20 AM
The VRPs RINKEBY and KUNGSHATT for ESSB are missing from the Skydemon database. They are important as they are waypoints on standard VFR ARR/DEP routes. (Ref. AIP-SWEDEN AD 2 ESSB 6-3 and 6-4).
Downloadable plates for ENGM doesn't include AIP-NORWAY AD 2 ENGM 6-3 which is the VAC for ENGM. Also the VRP NITTEDAL for ENGM which appears on Skydemon's chart appears to have been withdrawn.
By lhe - 5/24/2013 11:12:11 AM
They are not actually reporting points, but they are waypoints on the VFR routes (ref. AIP SWEDEN AD 2 ESSB 6-3/4).
If you e.g. enter Bromma CTR at ÄLVNÄS for landing RWY 30, you usually get an initial clearance to BJÖRNHOLMEN. A direct track would take you through restricted area ES R 24. You should route via KUNGSHATT. The same goes for departures RWY 12, exiting the CTR at ÄLVNÄS.
But ok, if you don't have "official" coordinates from the AIP, I can see why you might be reluctant to put them in the Skydemon database. It is certainly not a big deal for me to enter them as user waypoints.
