Weather Enroute
westie
westie
Too Much Forum (263 reputation)Too Much Forum (263 reputation)Too Much Forum (263 reputation)Too Much Forum (263 reputation)Too Much Forum (263 reputation)Too Much Forum (263 reputation)Too Much Forum (263 reputation)Too Much Forum (263 reputation)Too Much Forum (263 reputation)
Posts: 2, Visits: 8
Could someone tell me, whilst enroute, is there a way to get the WEATHER or NOTAM for an airport not presented in the METAR, TAF or NOTAM TABs - I'm using an IPAD2
Also I download PLATES and then they disappear - any ideas
I think I've read most info on here - any help gratefully received
Best - Westie
terrylp
terrylp
Posts: 6, Visits: 47
Mantino thats not the most helpful response.
westie - i assume you have a 3G iPad?
If you are suggesting you want to be flying a route and select an airfield not part of your route to check the weather there, i don't believe this is possible 'on the fly'. I suppose I would ask why might you want to do this? If you are in a situation where you need / want to divert you can select the new airfield and the either append to route or use direct to - provide you have 3G and your SD is set for online in flight mode it should refresh on all counts.
In terms of plates I personally havent had this issue - it keeps the plates that are based on my route - it doesn't download all plates and store them on the iPad only the ones relevant to the route. Same scenario above would apply i believe. Though I think you can select an airfield not in your route and select Find Plates from within the airfield menu.
Hope that helps.
westie
westie
Posts: 2, Visits: 8
Hi TMF,
Many thanks indeed.
The other day in extremely bad weather, minimum VFR, I was looking for divert options and to be able to just go to a weather tab and request a TAF/METAR would have been great - in a busy cockpit I didn't want to start playing too much with routes or, at that time, come off the route I was on. Just a simple quick and easy requirement for other weather information in order to make a real time decision.
Same idea for the plates - don't always know what you want in planning - i.e. the war plan doesn't survive the first battle ! I must admit I thought the program did download the plates that I selected.
SD is a fantastic program ! I'll keep playing with it until I find a work around.
Once again many tks - best - westie
Flylogical
Flylogical
Posts: 14, Visits: 43
westie (17/08/2012)
Hi TMF,
Many thanks indeed.
If you happen to have an internet connection in-flight (3G) -- SD would need such to get weather, in any case -- send an email to met@flylogical.com with your ICAO airport codes on the subject-line. You will get the METs and TAFs a few seconds later for each ICAO entry. You can also send same to plogs@flylogical.com . You will get MET and TAFs along the route defined by the ICAO codes, as opposed to the specific entries...
Otherwise, simply call-up LONDON or SCOTTISH on radio and ask for actuals at given location...
Edited 8/17/2012 12:12:51 PM by Flylogical
knorren
knorren
Posts: 26, Visits: 335
It is possible to get the weather for airports outside your planned.
Just click/point on the airport you want METAR/TAF (if available) for and then choose the airport and select Approach Information.
You then will get METAR/TAF and NOTAM for that airport.
