Weather Enroute
westie
westie
Too Much Forum (263 reputation)Too Much Forum (263 reputation)Too Much Forum (263 reputation)Too Much Forum (263 reputation)Too Much Forum (263 reputation)Too Much Forum (263 reputation)Too Much Forum (263 reputation)Too Much Forum (263 reputation)Too Much Forum (263 reputation)
Posts: 2, Visits: 8
Could someone tell me, whilst enroute, is there a way to get the WEATHER or NOTAM for an airport not presented in the METAR, TAF or NOTAM TABs - I'm using an IPAD2
Also I download PLATES and then they disappear - any ideas
I think I've read most info on here - any help gratefully received
Best - Westie
terrylp
terrylp
Posts: 6, Visits: 47
Mantino thats not the most helpful response.
westie - i assume you have a 3G iPad?
If you are suggesting you want to be flying a route and select an airfield not part of your route to check the weather there, i don't believe this is possible 'on the fly'. I suppose I would ask why might you want to do this? If you are in a situation where you need / want to divert you can select the new airfield and the either append to route or use direct to - provide you have 3G and your SD is set for online in flight mode it should refresh on all counts.
In terms of plates I personally havent had this issue - it keeps the plates that are based on my route - it doesn't download all plates and store them on the iPad only the ones relevant to the route. Same scenario above would apply i believe. Though I think you can select an airfield not in your route and select Find Plates from within the airfield menu.
Hope that helps.
