IPAD showing Offline
rpc41
rpc41
Posts: 9, Visits: 98
My IPAD 3 is showing offline (no network) in SkyDemon communications options. When I try to access Cloud storage I get a message saying there is no connection or the server is busy.
The unit is connected to to the internet by WIFI and the sim card is active. I can download mail and access the web through Safari so the connection is working.
The last time I had this I believe the fix was to turn off WIFI when it decided it had a connection, after which it was happy to operate once WIFI activated again. At the time I didn't note the detailed circumstances. Is there a way to force it to go look again and become online?
Richard
Posts: 593, Visits: 4.9K
Might be worth quitting and restarting SD.
Double tap the home button, then press and hold on the SD logo at the bottom. When the (-) appears, press it, then re-open SD.
Runways
Runways
Posts: 309, Visits: 1.6K
I noted a similar problem when SD is initiated before full WiFi connection is established on the iPad. One only needs to close and re-start SD after WiFi was fully established.
Can I add a query regarding the Glide Slope indicator which I have never seen on my iPad? Any sightings at all?
Also, I love the Pilot's log in flight. Is there a way of printing the complete Pilot's Log page off the iPad After the flight?
I apologise if these questions were answered elsewhere or if they intruded on the original thread.
Very Newbytheway
DurhamTeaseAirport
Edited 7/23/2012 6:44:16 AM by Runways
longfinals
longfinals
Posts: 10, Visits: 220
Has anybody else experienced this and have a fix. I have closed SD, disconnected and reconnected WiFi and still get a message saying the functionality cannot be used as an internet connection is not available when I know it definately is available.
Regards,
Crying
Sorry, I have never come across this.
Are you on a corporate network by any chance (behind a proxy for example).
Can you go to 'data.skydemon.aero' in Safari - you should get a 403 server error.
cct
cct
Posts: 31, Visits: 312
I am getting this as well. On a MiFi which is on-line, and I can get to data.skydemon.aero, where I get a 403.
Closed and restarted SD, but it resolutely stays off-line.
Any ides please?
Chris
cct
cct
Just solved this - didnt read the Communications options - select one of the Live data options, and it comes back.
guille
guille
Posts: 149, Visits: 2.4K
cct (14/02/2013)
I have also that problem, and it does not solve in my case. I have to restart the Ipad for getting the internet connection. If I do not restart, even with the communication menu indicating "online" for planning, the status keeps "offline". Closing SD and re-opening it does not solve the problem.
Tags
Edited 8/9/2013 1:41:39 PM by guille
guille
guille
Sorry to insist, but the problem remains. Even with the communications menu showing "online" for planning, even closing and reopening SD it keeps offline. It is necessary to close the Ipad, restart it, and it begins to work again. I would like to have an answer please : is this normal ? I checked and wifi connection was working with other applications without problem.
No, it's not normal. We've added some extra code to the next version which we hope will help.
