Skydemon 2.3 beta version posted 24 Jan 2012
srayne
srayne
Posts: 388, Visits: 8.3K
The link to valid aircraft type designators on the flight plan dialog no longer works - it should now be http://www.icao.int/publications/DOC8643/Pages/Doc8643.aspx
srayne
srayne
Using Plan: Deleting the last leg of a route sometimes generates a null reference exception as below.
System.NullReferenceException: Object reference not set to an instance of an object.
at Divelements.Aviation.FlightPlanner.Rendering.x867d3d2864d7f7d1.xffabc7d9909662a2(RhumbLineLeg xb04e2e8e28f7f89c)
at Divelements.Aviation.FlightPlanner.Rendering.x867d3d2864d7f7d1.x8b7f44d8b525e3de(RhumbLineLeg xb04e2e8e28f7f89c)
at Divelements.Aviation.FlightPlanner.Rendering.x970ba8497cedc724.xeb8fe09714135083(Object x4bbc2c453c470189)
at Divelements.Aviation.FlightPlanner.Rendering.x970ba8497cedc724.set_x61d6011f1af9ff95(Object xbcea506a33cf9111)
at Divelements.Aviation.FlightPlanner.Rendering.x970ba8497cedc724.xee988e0f5cd5978b(Point xb9c2cfae130d9256)
at Divelements.Aviation.FlightPlanner.Rendering.x970ba8497cedc724.OnMouseMove(MouseEventArgs e)
at System.Windows.Forms.Control.WmMouseMove(Message& m)
at System.Windows.Forms.Control.WndProc(Message& m)
at Divelements.Aviation.FlightPlanner.Rendering.x5cf3c184e49e0afe.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativewindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativewindow.WndProc(Message& m)
at System.Windows.Forms.Nativewindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.4216 (VistaSP2GDR.050727-4200)
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
SkyDemon
Assembly Version: 2.2.1.28502
Win32 Version:
CodeBase: file:///C:/Program%20Files/Divelements%20Limited/SkyDemon/SkyDemon.exe
Divelements.SandGrid
Assembly Version: 2.2.4.1
Win32 Version: 2.2.4.1
CodeBase: file:///C:/Program%20Files/Divelements%20Limited/SkyDemon/Divelements.SandGrid.DLL
Win32 Version: 2.0.50727.4214 (VistaSP2GDR.050727-4200)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
Win32 Version: 2.0.50727.4215 (VistaSP2GDR.050727-4200)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
Win32 Version: 2.0.50727.4016 (NetFxQFE.050727-4000)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
SandDock
Assembly Version: 3.0.6.1
Win32 Version: 3.0.6.1
CodeBase: file:///C:/Program%20Files/Divelements%20Limited/SkyDemon/SandDock.DLL
Assembly Version: 1.0.4406.28500
Win32 Version: 1.0.4406.28500
CodeBase: file:///C:/Program%20Files/Divelements%20Limited/SkyDemon/Divelements.Aviation.DLL
Divelements.Mapping
CodeBase: file:///C:/Program%20Files/Divelements%20Limited/SkyDemon/Divelements.Mapping.DLL
System.Xml
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
SandBar
Assembly Version: 1.4.3.1
Win32 Version: 1.4.3.1
CodeBase: file:///C:/Program%20Files/Divelements%20Limited/SkyDemon/SandBar.DLL
System.Configuration
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
OpenNETCF.Desktop.Communication
Assembly Version: 2.9.4071.29397
Win32 Version: 2.9.4071.29397
CodeBase: file:///C:/Program%20Files/Divelements%20Limited/SkyDemon/OpenNETCF.Desktop.Communication.DLL
Thanks, we've updated our link to ICAO.
The other issue you raise is very interesting, I've tried but haven't managed to reproduce it. Is there a specific set of steps that if I follow it enough, will show the fault?
srayne
srayne
Load the attached route (rename .txt to .flightplan)
Then click on the final leg of the route (eden project to newquay) to highlight it and press the 'del' key to remove the leg. Sometimes if this does not fail then right click on newquay and append it back to the route and delete the last leg again as described above this will always cause the exception within two or three attempts.
I've also added the aircraft file in case this is relevent.
Version 2.2.1.28502
Simon
PA28R-200.txt (526 views, 1.00 KB)
Edited 1/25/2012 10:30:34 PM by srayne
nje
nje
Posts: 384, Visits: 4.2K
Good Morning, I just tried putting in any old route e.g. Sleap to Hawarden to Tatenhill and then deleted the last leg by highlighting and then pressing the delete key. ( I don't normally delete the legs in this way, I normally right click and do it that way) If you delete it by right clicking then there doesn't seem to be a problem. This is what I got
 " Unhandled exception has occurred in your application. If you click on Continue the application will ignore the error and attempt to continue. If you click on quit the application will close immediately. Object reference not set to an instance of an object"
mscorlib
    Win32 Version: 2.0.50727.4927 (NetFXspW7.050727-4900)
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v2.0.50727/mscorlib.dll
SkyDemon
    Win32 Version:
    CodeBase: file:///C:/Program%20Files%20(x86)/Divelements%20Limited/SkyDemon/SkyDemon.exe
    CodeBase: file:///C:/Program%20Files%20(x86)/Divelements%20Limited/SkyDemon/Divelements.Aviation.DLL
System
System.Drawing
    CodeBase: file:///C:/Program%20Files%20(x86)/Divelements%20Limited/SkyDemon/Divelements.SandGrid.DLL
SandDock
    CodeBase: file:///C:/Program%20Files%20(x86)/Divelements%20Limited/SkyDemon/SandDock.DLL
Divelements.Mapping
    CodeBase: file:///C:/Program%20Files%20(x86)/Divelements%20Limited/SkyDemon/Divelements.Mapping.DLL
System.Xml
SandBar
    CodeBase: file:///C:/Program%20Files%20(x86)/Divelements%20Limited/SkyDemon/SandBar.DLL
enabled.
For example:
<configuration>
</configuration>
Edited 1/26/2012 9:22:22 AM by nje
srayne
srayne
It doesn't even have to be the last leg of a route, I have found that I can reproduce the exception by deleting an intermediate leg using the click to highlight leg then 'del' key to delete leg.
Thanks, we managed to reproduce the issue this morning and have made a change which should fix it. It certainly has in our tests.
