Skydemon 2.3 beta version posted 24 Jan 2012
srayne
srayne
Posts: 388, Visits: 8.3K
The link to valid aircraft type designators on the flight plan dialog no longer works - it should now be http://www.icao.int/publications/DOC8643/Pages/Doc8643.aspx
nje
nje
Posts: 384, Visits: 4.2K
Good Morning, I just tried putting in any old route e.g. Sleap to Hawarden to Tatenhill and then deleted the last leg by highlighting and then pressing the delete key. ( I don't normally delete the legs in this way, I normally right click and do it that way) If you delete it by right clicking then there doesn't seem to be a problem. This is what I got
 " Unhandled exception has occurred in your application. If you click on Continue the application will ignore the error and attempt to continue. If you click on quit the application will close immediately. Object reference not set to an instance of an object"
System.NullReferenceException: Object reference not set to an instance of an object.
   at Divelements.Aviation.FlightPlanner.Rendering.x867d3d2864d7f7d1.xffabc7d9909662a2(RhumbLineLeg xb04e2e8e28f7f89c)
   at Divelements.Aviation.FlightPlanner.Rendering.x867d3d2864d7f7d1.x8b7f44d8b525e3de(RhumbLineLeg xb04e2e8e28f7f89c)
   at Divelements.Aviation.FlightPlanner.Rendering.x970ba8497cedc724.xeb8fe09714135083(Object x4bbc2c453c470189)
   at Divelements.Aviation.FlightPlanner.Rendering.x970ba8497cedc724.set_x61d6011f1af9ff95(Object xbcea506a33cf9111)
   at Divelements.Aviation.FlightPlanner.Rendering.x970ba8497cedc724.xee988e0f5cd5978b(Point xb9c2cfae130d9256)
   at Divelements.Aviation.FlightPlanner.Rendering.x970ba8497cedc724.OnMouseMove(MouseEventArgs e)
   at System.Windows.Forms.Control.WmMouseMove(Message& m)
   at System.Windows.Forms.Control.WndProc(Message& m)
   at Divelements.Aviation.FlightPlanner.Rendering.x5cf3c184e49e0afe.WndProc(Message& m)
   at System.Windows.Forms.Control.ControlNativewindow.WndProc(Message& m)
   at System.Windows.Forms.Nativewindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
mscorlib
    Assembly Version: 2.0.0.0
    Win32 Version: 2.0.50727.4927 (NetFXspW7.050727-4900)
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v2.0.50727/mscorlib.dll
SkyDemon
    Assembly Version: 2.2.1.28502
    Win32 Version:
    CodeBase: file:///C:/Program%20Files%20(x86)/Divelements%20Limited/SkyDemon/SkyDemon.exe
    Assembly Version: 1.0.4406.28500
    Win32 Version: 1.0.4406.28500
    CodeBase: file:///C:/Program%20Files%20(x86)/Divelements%20Limited/SkyDemon/Divelements.Aviation.DLL
System
System.Drawing
Divelements.SandGrid
    Assembly Version: 2.2.4.1
    Win32 Version: 2.2.4.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Divelements%20Limited/SkyDemon/Divelements.SandGrid.DLL
SandDock
    Assembly Version: 3.0.6.1
    Win32 Version: 3.0.6.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Divelements%20Limited/SkyDemon/SandDock.DLL
Divelements.Mapping
    CodeBase: file:///C:/Program%20Files%20(x86)/Divelements%20Limited/SkyDemon/Divelements.Mapping.DLL
System.Xml
SandBar
    Assembly Version: 1.4.3.1
    Win32 Version: 1.4.3.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Divelements%20Limited/SkyDemon/SandBar.DLL
System.Configuration
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
enabled.
For example:
<configuration>
</configuration>
Edited 1/26/2012 9:22:22 AM by nje
srayne
srayne
It doesn't even have to be the last leg of a route, I have found that I can reproduce the exception by deleting an intermediate leg using the click to highlight leg then 'del' key to delete leg.
