Skydemon 2.3 beta version posted 24 Jan 2012
srayne
srayne
posted 1/25/2012 11:26:00 AM
Visits: 8.3K
The link to valid aircraft type designators on the flight plan dialog no longer works - it should now be
http://www.icao.int/publications/DOC8643/Pages/Doc8643.aspx
srayne
srayne
posted 1/25/2012 8:52:01 PM
Visits: 8.3K
Load the attached route (rename .txt to .flightplan)
Then click on the final leg of the route (eden project to newquay) to highlight it and press the 'del' key to remove the leg. Sometimes if this does not fail then right click on newquay and append it back to the route and delete the last leg again as described above this will always cause the exception within two or three attempts.
I've also added the aircraft file in case this is relevent.
Version 2.2.1.28502
Simon
PA28R-200.txt
528 views,
1.00 KB
top farm - newquay (south route).txt
516 views,
4.00 KB
Edited
1/25/2012 10:30:34 PM by
srayne
srayne
Using Plan: Deleting the last leg of a route sometimes generates a...
srayne
1/25/2012 11:30:30 AM
Thanks, we've updated our link to ICAO. The other issue you raise is...
1/25/2012 1:28:45 PM
Load the attached route (rename .txt to...
srayne
Good Morning, I just tried putting in any old route e.g. Sleap to...
nje
1/26/2012 9:18:58 AM
It doesn't even have to be the last leg of a route, I have found that...
srayne
1/26/2012 9:56:20 AM
Thanks, we managed to reproduce the issue this morning and have made a...
1/26/2012 11:51:48 AM
