Select VOR/DME for PLOG Column
BS
B
Too Much Forum (165 reputation)Too Much Forum (165 reputation)Too Much Forum (165 reputation)Too Much Forum (165 reputation)Too Much Forum (165 reputation)Too Much Forum (165 reputation)Too Much Forum (165 reputation)Too Much Forum (165 reputation)Too Much Forum (165 reputation)
Posts: 32, Visits: 430
Would it be possible to be able to select a specified VOR/DME for showing on the PLOG in the RNAV column?
I went to Redhill and from a cockpit management point of view it was easier to note the range/bearing to a consistent VOR/DME station.  However, SD used CPT, then OCK and finally BIG and I didn't want to retune and identify 3 separate stations.  So I selected Midhurst (MID) as it gave me the best range/bearing from a single source.
Could have used Biggin (BIG) instead but the point is it would be easier to use a single RNAV for a particular phase of flight rather than the arithmetic closest which changes 3 times while doing a zone crossing and final phase of flight.
BS
B
BS - 8/18/2025 10:24:51 AM
Any thoughts on this Tim?
I see the problem, but I think it very unlikely we would implement the feature as suggested. Partly because very few SkyDemon users are still using VOR navigation, but also because we'd need quite a lot of people to contribute to this thread indicating they also face the problem.
Posts: 655, Visits: 32K
Something that might help is using the 'Track Waypoint' feature.
- Long press the single VOR you want to track, to display the 'What's here' pop-up
- Touch the VOR in the 'Waypoints' section at the top
- Touch 'Track Waypoint' in the 'Navigation' section at the top
A running Radial and Distance from the VOR will be shown in the black bar at the top of the chart. I will disappear though if you touch it.
BS
B
grahamb - 9/3/2025 11:09:03 AM
Yes I think that is what I did.  The track waypoint feature told me where SD said I was (radial/bearing from MID) and I cross checked that against the range/bearing from the onboard VOR/DME equipment.
BS
B
Tim Dawson - 9/3/2025 8:58:10 AM
I suppose my point was if the PLOG RNAV vectors is just the arithmetic closest and so could be against different VOR's on a route, it is really very useful then?
Boeingboy
Boeingboy
Too Much Forum (625 reputation)Too Much Forum (625 reputation)Too Much Forum (625 reputation)Too Much Forum (625 reputation)Too Much Forum (625 reputation)Too Much Forum (625 reputation)Too Much Forum (625 reputation)Too Much Forum (625 reputation)Too Much Forum (625 reputation)
Posts: 59, Visits: 638
" Partly because very few SkyDemon users are still using VOR navigation"
I still have a KNS80 in my aircraft with which I utilise RNAV data. There are still some of oldies out there flying little bits of navigational history! Tongue
And is our RNav pilot log column feature of use to you?
