Select VOR/DME for PLOG Column
http://forums.skydemon.aero/Topic38287.aspx
By BS - 8/18/2025 10:24:51 AM
Would it be possible to be able to select a specified VOR/DME for showing on the PLOG in the RNAV column?
I went to Redhill and from a cockpit management point of view it was easier to note the range/bearing to a consistent VOR/DME station.  However, SD used CPT, then OCK and finally BIG and I didn't want to retune and identify 3 separate stations.  So I selected Midhurst (MID) as it gave me the best range/bearing from a single source.
Could have used Biggin (BIG) instead but the point is it would be easier to use a single RNAV for a particular phase of flight rather than the arithmetic closest which changes 3 times while doing a zone crossing and final phase of flight.
By Tim Dawson - 9/8/2025 9:50:37 AM
And is our RNav pilot log column feature of use to you?
