Exporting flight history into Google Earth
doconnor74
doconnor74
Posts: 6, Visits: 30
Just used the 30min trial of Mobile and have exported the route log into a google earth file (via http://www.gpsvisualizer.com)
All worked fine, but just produced a flat route. On my Bendix AV8OR (which I loaded up SD onto) the native software produced google earth files like the attached which shows height info - any way of doing the same with the logs out of SD ?
Cheers
Danny
doconnor74
doconnor74
Let's try the image again
doconnor74
doconnor74
Sorry, think this link will let you see a bigger version (can't edit my posts due to post count I guess)
From SD
In what format does the route come out of your AV80R software before being translated into a Google file?
doconnor74
doconnor74
Hi Tim, it automatically creates .kml files.
I've attached one (renamed the extension to .txt)
thanks
Danny
16 Nov 2009.txt (939 views, 264.00 KB)
Thanks. We'll consider flightlog export directly in KML format in the future.
doconnor74
doconnor74
Thanks Tim !
2high2fastagain
2high2fastagain
Posts: 43, Visits: 98
I've had no problem with reliving my famous flights via Skydemon mobile and Google Earth. I use the full Skydemon version and it's great fun. What I do is:
1. Synch the mobile with the Skydemon PC version after the flight so your log gets loaded into Skydemon
2. Export the log from Skydemon as a GPX file
3. Import the GPX directly into Google Earth - taking care to uncheck the 'Adjust altitudes to ground level' in the GPS data import that Google Earth throws up. I also leave the KML Groundstrings unchecked, but I do check the KML tracks box.
4. Go into Google Earth and enjoy. I've set up the touring options like this (see below) and it allows me to relive the flight by clicking on that little folder icon at the bottom of the places window
Rob P
Rob P
Posts: 24, Visits: 141
2high2fastagain (11/08/2011)
Ah, now that is where I am coming unstuck as I cannot see any way to export the file as anything - let alone a GPX file.
The 'export' option is greyed out on my SkyDemon
Rob P
Admin
Admin
Too Much Forum (6.1K reputation)Too Much Forum (6.1K reputation)Too Much Forum (6.1K reputation)Too Much Forum (6.1K reputation)Too Much Forum (6.1K reputation)Too Much Forum (6.1K reputation)Too Much Forum (6.1K reputation)Too Much Forum (6.1K reputation)Too Much Forum (6.1K reputation)
Group: Administrators
Posts: 48, Visits: 212
Click on your log (its virtual radar output) so it's selected then the option will become available.
