Exporting flight history into Google Earth
http://forums.skydemon.aero/Topic3765.aspx
By doconnor74 - 8/7/2011 9:52:11 PM
Just used the 30min trial of Mobile and have exported the route log into a google earth file (via http://www.gpsvisualizer.com)
All worked fine, but just produced a flat route. On my Bendix AV8OR (which I loaded up SD onto) the native software produced google earth files like the attached which shows height info - any way of doing the same with the logs out of SD ?
Cheers
Danny
By tonton-h4 - 1/8/2024 4:48:08 PM
Good afternoon,
If I export kml or gpx log files and I import them into Google Earth, I have the feeling data is missing.
The trace is shown, but if you click on one point of the trace, a pop up window appears but no data is displayed.
Do I have a problem inside Google Earth?  Since the trace is shown, data is available for Google Earth.
When I am using "https://www.flysto.net", the same file (KML or GPX) shows the speed, altitude.
Thanks a lot if you can show me the way to have readable data in Earth.
Dan.
