Disconnections while using SD with Stratux in Flarm mode
matthiasdols
m
Forum Member (27 reputation)Forum Member (27 reputation)Forum Member (27 reputation)Forum Member (27 reputation)Forum Member (27 reputation)Forum Member (27 reputation)Forum Member (27 reputation)Forum Member (27 reputation)Forum Member (27 reputation)
Posts: 2, Visits: 1
I use Skydemon together with a Stratux in the version 1.6r1-eu028 (32d5e58b7f) to receive the traffic and the GPS-Signal of the Stratux. When I start the flying mode in Skydemon and use the option ""Use Flarm with Air Connect" I have problems with my connection to the Wifi, which means, that I receive the error message "Reconnecting to device" by Skydemon, sometimes one time in a minute. This error message doesn't occur when I use the option "Use GDL90 Compatible Device". Does anyone know the reason for those errors and what can be done to avoid having such disconnections in Flaum-Mode?
Any help would be much appreciated.
kyza
k
Forum Member (28 reputation)Forum Member (28 reputation)Forum Member (28 reputation)Forum Member (28 reputation)Forum Member (28 reputation)Forum Member (28 reputation)Forum Member (28 reputation)Forum Member (28 reputation)Forum Member (28 reputation)
Posts: 3, Visits: 0
Hello. We have similar problem.
We have Power Flarm connected to USR-W610 through RS 232. Than we have iPad connected to wifi (USR-W610) where SkyDemon is running.
Continuously we loosing connection on SkyDemon to PowerFlarm. Lets say every 15-30 seconds SkyDemon says lost connection re-authenticating. We can see all ADSB and FLARM traffic on SkyDemon without problem. But that reconnections are annoying.
We checked that ping from iPad to wifi is stable so we think the problem is within SkyDemon.
It seems to me that this problem started after last update aprox. month ago.
Version we have is 3.16.10.
Can someoen help us ? 🙂 Thank you in Advance.
TouchTheSky
T
Posts: 153, Visits: 4.5K
This is very likely the same issue that has already been reported in this thread: http://forums.skydemon.aero/Topic36398.aspx
SD team is currently looking into this and will hopefully come back soon with a solution.
kyza
k
Posts: 3, Visits: 0
TouchTheSky - 11/5/2023 1:25:55 PM
Thank you for info.
Kyza
