Since latest Update, Connection between Stratux and Skydemon not stable!
larbiere
larbiere
Too Much Forum (674 reputation)Too Much Forum (674 reputation)Too Much Forum (674 reputation)Too Much Forum (674 reputation)Too Much Forum (674 reputation)Too Much Forum (674 reputation)Too Much Forum (674 reputation)Too Much Forum (674 reputation)Too Much Forum (674 reputation)
Posts: 4, Visits: 84
Dear SkyDemon team,
Since the last SkyDemon update (3.16.10 on September 26th), the Wi-Fi connection between SkyDemon and my Stratux device is no longer stable. Both the GPS position and the transmitted traffic signal from the Stratux constantly disappear, and the message "Authenticating" appears in SkyDemon. I am using an iPhone X and an iPad Mini 4. Both devices exhibit the same behavior after the update. Thank you very much for your assistance!
Sincerely,
Jean-Paul Larbiere
Joachim Gothe
Joachim Gothe
Too Much Forum (210 reputation)Too Much Forum (210 reputation)Too Much Forum (210 reputation)Too Much Forum (210 reputation)Too Much Forum (210 reputation)Too Much Forum (210 reputation)Too Much Forum (210 reputation)Too Much Forum (210 reputation)Too Much Forum (210 reputation)
Posts: 19, Visits: 58
Same Problem with an IOS17 iPad mini 6 but with the Flightsimulator MSFS via Xmapsy 3.2 GDL90 protokol.
It works for many years but now connection lost every 1x seconds. Unusable !!
iPad and PC are on the same Wifi/kabel Network.
Not tested in my RV6 with AirAvionics AT-1.
Achim
Edited 10/2/2023 7:56:40 PM by Joachim Gothe
A few customers have reported connection stability issues since "upgrading" to iOS 17. We haven't been able to reproduce them yet at SkyDemon. We are hoping that Apple locate and fix the problem.
Turmfalke
T
Junior Member (24 reputation)Junior Member (24 reputation)Junior Member (24 reputation)Junior Member (24 reputation)Junior Member (24 reputation)Junior Member (24 reputation)Junior Member (24 reputation)Junior Member (24 reputation)Junior Member (24 reputation)
Posts: 2, Visits: 0
Dear Tim,
I haven‘t updated to IOS17, I am using iPadOS 16.7 on an iPad mini 6, as well as IOS 16.7 on an iPhone 13 pro.
Nevertheless i have been experiencing the same connection issues since updating skydemon to the latest version. Before the update the connection was stable on both devices.
Thank you for your support
matthiasdols
m
Forum Member (27 reputation)Forum Member (27 reputation)Forum Member (27 reputation)Forum Member (27 reputation)Forum Member (27 reputation)Forum Member (27 reputation)Forum Member (27 reputation)Forum Member (27 reputation)Forum Member (27 reputation)
Posts: 2, Visits: 1
I have the same issue with an iPad 11 and an iPad Air 10.9, both with iOS 17 and the latest version of Skydemon. The connection issues happen since the last update to the latest version of Skydemon.
I also would appreciate your support.
Ok, what devices are you experiencing problems connecting to? I can see one person says Stratux, one person says a flight simulator.
Turmfalke
T
Posts: 2, Visits: 0
I am using GS-Traffic2WIFIv2 from GS-Avionic. The device is connected to a TRX-2000. In the past I never had any issues with the connection.
Tim, if you could provide the previous version of SkyDemon I could test this at the weekend in my airplane and give you feedback as soon as possible.
Hope this helps.
Kind regards
TouchTheSky
T
Too Much Forum (6.3K reputation)Too Much Forum (6.3K reputation)Too Much Forum (6.3K reputation)Too Much Forum (6.3K reputation)Too Much Forum (6.3K reputation)Too Much Forum (6.3K reputation)Too Much Forum (6.3K reputation)Too Much Forum (6.3K reputation)Too Much Forum (6.3K reputation)
Posts: 153, Visits: 4.6K
I am also having Stratux issues but only when connecting via FLARM-NMEA. GDL90 seems to work - usually it has bee the other way round.
It isn't possible to provide previous versions of iOS apps, unfortunately.
TouchTheSky
T
Tim, just to be clear - the Stratux firmware has not been changed for quite some time and particularly no change to the FLARM-NMEA connection but both SD and iOS have been updated ..
