Disconnections while using SD with Stratux in Flarm mode
http://forums.skydemon.aero/Topic36405.aspx
By matthiasdols - 10/3/2023 4:54:15 PM
I use Skydemon together with a Stratux in the version 1.6r1-eu028 (32d5e58b7f) to receive the traffic and the GPS-Signal of the Stratux. When I start the flying mode in Skydemon and use the option ""Use Flarm with Air Connect" I have problems with my connection to the Wifi, which means, that I receive the error message "Reconnecting to device" by Skydemon, sometimes one time in a minute. This error message doesn't occur when I use the option "Use GDL90 Compatible Device". Does anyone know the reason for those errors and what can be done to avoid having such disconnections in Flaum-Mode?
Any help would be much appreciated.
By kyza - 11/5/2023 2:03:05 PM
TouchTheSky - 11/5/2023 1:25:55 PM
This is very likely the same issue that has already been reported in this thread: http://forums.skydemon.aero/Topic36398.aspx
SD team is currently looking into this and will hopefully come back soon with a solution.
Thank you for info.
Kyza
