Since latest Update, Connection between Stratux and Skydemon not stable!
TWST
T
Posts: 1, Visits: 0
Since the last SkyDemon update, the WiFi connection between SkyDemon and the PowerFlarm Fusion device is no longer stable. Sometimes the connection is not established or the GPS position as well as the traffic signal transmitted by Flarm constantly disappear and the message “Authentication in progress” appears in SkyDemon. I'm using an iPad Mini 5. Thanks for your help!
Greetings Georg
TouchTheSky
T
Posts: 153, Visits: 4.6K
Tim Dawson - 10/17/2023 9:12:08 AM
Thanks, my colleague tells me we've already received a positive response so hopefully there's one on its way to us.
Correct, I will ship the device hopefully no later than tomorrow.
TouchTheSky
T
Tim Dawson - 10/16/2023 9:25:07 AM
I believe we've reached out to Stratux to see if we can borrow a unit for testing purposes.
Tim, I am part of the Stratux Europe team - in case you need a device, just drop an Email to info@stratux.de
greg
greg
Posts: 34, Visits: 202
The same problem recently appeared here as well. My old  Ipad  (IOS 12.5.7) SkyDemon 3.16.10.373 would not connect anymore with “Flarm with Air Connect”.
It would either say "connecting" or "authenticating" forever.
My Samsung smart phone connects.
Johannes B.
J
Too Much Forum (712 reputation)Too Much Forum (712 reputation)Too Much Forum (712 reputation)Too Much Forum (712 reputation)Too Much Forum (712 reputation)Too Much Forum (712 reputation)Too Much Forum (712 reputation)Too Much Forum (712 reputation)Too Much Forum (712 reputation)
Posts: 53, Visits: 1
Same here on 3 ios devices. My Androids work flawlessly with stratux.
YouTube channel
Duplo00
D
Posts: 1, Visits: 0
Same problem for me. Connections drop every few seconds.
iPhone SE, iOS 17.0.3,
Skydemon 3.16.10.373,
Connection with Stratux via “Flarm with Air Connect”.
Before the Skydemon and iOS update it was very stable.
TouchTheSky
T
Tim, just to be clear - the Stratux firmware has not been changed for quite some time and particularly no change to the FLARM-NMEA connection but both SD and iOS have been updated ..
It isn't possible to provide previous versions of iOS apps, unfortunately.
