Since latest Update, Connection between Stratux and Skydemon not stable!
Duplo00
D
Junior Member (14 reputation)Junior Member (14 reputation)Junior Member (14 reputation)Junior Member (14 reputation)Junior Member (14 reputation)Junior Member (14 reputation)Junior Member (14 reputation)Junior Member (14 reputation)Junior Member (14 reputation)
Posts: 1, Visits: 0
Same problem for me. Connections drop every few seconds.
iPhone SE, iOS 17.0.3,
Skydemon 3.16.10.373,
Connection with Stratux via “Flarm with Air Connect”.
Before the Skydemon and iOS update it was very stable.
Johannes B.
J
Too Much Forum (860 reputation)Too Much Forum (860 reputation)Too Much Forum (860 reputation)Too Much Forum (860 reputation)Too Much Forum (860 reputation)Too Much Forum (860 reputation)Too Much Forum (860 reputation)Too Much Forum (860 reputation)Too Much Forum (860 reputation)
Posts: 54, Visits: 1
Same here on 3 ios devices. My Androids work flawlessly with stratux.
YouTube channel
greg
greg
Posts: 34, Visits: 202
The same problem recently appeared here as well. My old  Ipad  (IOS 12.5.7) SkyDemon 3.16.10.373 would not connect anymore with “Flarm with Air Connect”.
It would either say "connecting" or "authenticating" forever.
My Samsung smart phone connects.
I believe we've reached out to Stratux to see if we can borrow a unit for testing purposes.
TouchTheSky
T
Posts: 153, Visits: 4.6K
Tim Dawson - 10/16/2023 9:25:07 AM
Tim, I am part of the Stratux Europe team - in case you need a device, just drop an Email to info@stratux.de
Thanks, my colleague tells me we've already received a positive response so hopefully there's one on its way to us.
TouchTheSky
T
Tim Dawson - 10/17/2023 9:12:08 AM
Correct, I will ship the device hopefully no later than tomorrow.
TWST
T
Junior Member (13 reputation)Junior Member (13 reputation)Junior Member (13 reputation)Junior Member (13 reputation)Junior Member (13 reputation)Junior Member (13 reputation)Junior Member (13 reputation)Junior Member (13 reputation)Junior Member (13 reputation)
Posts: 1, Visits: 0
Since the last SkyDemon update, the WiFi connection between SkyDemon and the PowerFlarm Fusion device is no longer stable. Sometimes the connection is not established or the GPS position as well as the traffic signal transmitted by Flarm constantly disappear and the message “Authentication in progress” appears in SkyDemon. I'm using an iPad Mini 5. Thanks for your help!
Greetings Georg
kyza
k
Forum Member (38 reputation)Forum Member (38 reputation)Forum Member (38 reputation)Forum Member (38 reputation)Forum Member (38 reputation)Forum Member (38 reputation)Forum Member (38 reputation)Forum Member (38 reputation)Forum Member (38 reputation)
Posts: 3, Visits: 0
TWST - 10/18/2023 12:33:45 PM
Greetings Georg
We have exactly same problem with SD.
We have Power Flarm Portable connected to USR-W610 through RS 232. Than we have iPad, iPhone latest versions connected to wifi (USR-W610) where SkyDemon is running.
Continuously we loosing connection on SkyDemon to PowerFlarm. Lets say every 15-30 seconds SkyDemon says lost connection re-authenticating. We can see all ADSB and FLARM traffic on SkyDemon without problem. But that reconnections are annoying.
We checked that ping from iPad to wifi is stable so we think the problem is within SkyDemon.
Thank you for your help.
Kyza
gs-avionik.de
g
Too Much Forum (61 reputation)Too Much Forum (61 reputation)Too Much Forum (61 reputation)Too Much Forum (61 reputation)Too Much Forum (61 reputation)Too Much Forum (61 reputation)Too Much Forum (61 reputation)Too Much Forum (61 reputation)Too Much Forum (61 reputation)
Posts: 4, Visits: 0
i'm the developer of the GS-Traffic2WIFI devices, which are affected from the problem, too. Today I did some tests with the following results:
iOS / iPad OS 15.7.4 mit SD 3.16.7.359    :     OK
iOS / iPad OS 15.8 mit SD 3.6.10.373     :     not OK
iOS / iPad OS 17.1 mit SD 3.6.10.373     :     not OK
iOS / iPad OS 17.1.1 mit SD 3.6.10.373     :     not OK
iOS / iPad OS 17.0.3 mit SD 3.16.9.367    :     OK
iOS / iPad OS 17.1.1 mit SD 3.16.9.367    :     OK
iOS / iPad OS 17.1.1 mit SD 3.16.10.373    :     not OK
"not OK" means, WIFI-Connection between the devices is stable but Skydemon looses connection and then reconnects with small interrupts. I think it isn't an ios-issue and there has to be a change at SkyDemon (as the results show). As i wrote to the support-mail address I can provide a test-unit if that helps.
