Kilo Lima
K
Too Much Forum (383 reputation)Too Much Forum (383 reputation)Too Much Forum (383 reputation)Too Much Forum (383 reputation)Too Much Forum (383 reputation)Too Much Forum (383 reputation)Too Much Forum (383 reputation)Too Much Forum (383 reputation)Too Much Forum (383 reputation)
Posts: 12, Visits: 0
I_Need_Help - 9/3/2024 9:15:58 AM
Kilo Lima - 9/3/2024 9:12:11 AM
Kilo Lima - 8/28/2024 5:00:33 PM
I’m wondering where you connect the 5v supply for the Bluetooth module in your aircraft?
Thanks!
Any idea please? Thanks for your help!
That will depend on your aircraft type and what rules you operate under e,.g. certified, LAA or BMAA
It’s an Experimental aircraft equipped with a Rotax 912. Easy to do some modifications under French rules. Thanks
Kilo Lima
K
It’s a French experimental equipped with a Rotax 912. Easy to do some modifications under this French rules. Thanks
I_Need_Help
I_Need_Help
Too Much Forum (550 reputation)Too Much Forum (550 reputation)Too Much Forum (550 reputation)Too Much Forum (550 reputation)Too Much Forum (550 reputation)Too Much Forum (550 reputation)Too Much Forum (550 reputation)Too Much Forum (550 reputation)Too Much Forum (550 reputation)
Posts: 11, Visits: 10
I have had good results with these in past
https://www.ebay.co.uk/itm/193552404580?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=UdLxmPhjSYW&sssrc=4429486&ssuid=M5gVARi1SJS&var=493775050618&widget_ver=artemis&media=COPY
Also many people also fit a 12v socket and use a car usb adaptor but get a good make or you may get noise!
Kilo Lima
K
I_Need_Help - 9/4/2024 11:01:15 AM
I have had good results with these in past https://www.ebay.co.uk/itm/193552404580?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=UdLxmPhjSYW&sssrc=4429486&ssuid=M5gVARi1SJS&var=493775050618&widget_ver=artemis&media=COPYAlso many people also fit a 12v socket and use a car usb adaptor but get a good make or you may get noise!
Ok, thank you for your help. I will investigate for a converter.
I think this is the only way to supply 5v to the Bluetooth module.
Kilo Lima
K
Or perhaps it’s possible to find a 12v Bluetooth module????
Ben
Ben
Posts: 32, Visits: 47
Michael Hoffmann - 8/26/2024 8:12:27 PM
I have connected a DSD TECH HM-10 Bluetooth 4.0 BLE iBeacon UART module and can receive the "COM setting data" via RS232.
This works really well.
Is there a list of supported radios and their data format?
Now I'm faced with the problem of wanting to control a Becker AR 6201 radio. It has an RS-422 interface. It shouldn't be a problem to convert RS232 to RS422, but the data format is unknown. Can anyone help?
Thanks in advance
Michael
Michael,
I'm trying to prevent the back of my panel looking like a PAW Classic... these wee units look far better for mounting.  Can you confirm that they can output RS232 sentances for avionics?  Are any resistors needed?
jekroth
j
Too Much Forum (303 reputation)Too Much Forum (303 reputation)Too Much Forum (303 reputation)Too Much Forum (303 reputation)Too Much Forum (303 reputation)Too Much Forum (303 reputation)Too Much Forum (303 reputation)Too Much Forum (303 reputation)Too Much Forum (303 reputation)
Posts: 21, Visits: 0
vikino - 8/4/2023 7:57:32 PM
Well...
I have tested theese BT-RS232 modules a lot by my self, it works great with Dynon EFIS-D100 + AP74 autopilot and Trig TY96 COM radio, also without any issue with KRT2 COM radio. You just need to "match" baudrate to 4800 or 9600bps, that should do in this case SkyDemon, afterwards it works like a charm, no drop outs with Samsung tablets or my phone Samsung S23 Ultra.
And all another BT to RS232 work in the same way like this one, all are in the phone as bluetooth com port, all this seems to me much easier and more stable than 3rd party devices which are connected over wifi. Not talking about that you kill your internal data sim when connected to wifi of "ADAHRS" and so on...
This will just work perfectly.
Btw., with this, you can go to compleete system, because when you connect to this serial converter also Garrecht TRX1500 (for example), you can use SkyDemon as traffic display - by using GTX TIS protocol over that single BT-RS232 module.
In the same way i have it with Garmin AERA 760, but planning a route is terrible on that device, but Garmin has built in RS232...
Tim Dawson - 7/5/2023 9:13:53 AM
No, not until there is a device with widespread uptake in the community that we can actually develop with. We can't just "support Bluetooth" without a known device to develop and test with.
I have now flown a bit with both radio and autopilot connected to each blue tooth unit, and it works perfectly. My experience is that it is easy to accidentally press a new radio frequency if the air is bumpy, so I have chosen that they end up in standby mode, therefore a request for a button to switch standby/active in skydemon, also a numeric keyboard in the radio tab would be good. the auto pilot has everything I could wish for
moefly
m
Too Much Forum (123 reputation)Too Much Forum (123 reputation)Too Much Forum (123 reputation)Too Much Forum (123 reputation)Too Much Forum (123 reputation)Too Much Forum (123 reputation)Too Much Forum (123 reputation)Too Much Forum (123 reputation)Too Much Forum (123 reputation)
Posts: 10, Visits: 0
All,
I was very excited when I read about the feature in the Skydemon release note, went right into ordering parts and figured I share the experience here.
Top 1 priority for me was to get the radio (f.u.n.k.e. ATR833-II) connected. So I designed a 3d case that perfectly fits on top of the original Sub-D connector housing and uses the existing screw holes (only needed slightly longer screws). Once mounted, it sits below the connector at the back of the radio and doesn't block anything else / basically uses the same space.
I decided to use a HM-18 BLE to serial module. It is very power efficient and therefore I could easily use the 5V the radio provides on the Sub-D connector. The HM-18 is outputting TTL serial, hence I added a MAX3232 converter to provide the proper RS232 levels the radio expects.
Put everything together and it worked right away. For me it's almost a killer feature in Skydemon as it makes my life so much more simple during flight.
A big thx to Tim and his team for adding this feature!
In case anyone is interested in the 3d model and a more detailed info on connection and parts I used, you can find all of that here on printables:
https://www.printables.com/model/1015550-funke-atr833-ble-rs232-case
Edited 9/22/2024 5:00:47 PM by moefly
Nicely done!
vikino
v
Too Much Forum (766 reputation)Too Much Forum (766 reputation)Too Much Forum (766 reputation)Too Much Forum (766 reputation)Too Much Forum (766 reputation)Too Much Forum (766 reputation)Too Much Forum (766 reputation)Too Much Forum (766 reputation)Too Much Forum (766 reputation)
Posts: 40, Visits: 98
Hello Tim,
have you got any time schedule about programming ability to send AP+COM and receive traffic via single BT-RS232? Just to know if i should wire second BT device or you can get it to work in near future?
Vitek
