bjornbostrom
Visits: 52
Hi, after upgrading to the latest version 3.15.0.0 on PC i get the following errormessage when starting SkyDemon. Any suggestion what might be wrong? br // björn
Microsoft .NET Framework Exception
System.InvalidOperationException: Åtgärden är ogiltig på grund av objektets aktuella tillstånd. vid Divelements.SkyDemon.Drawing.IndependentText.CreateMeasurementGraphics() vid Divelements.SkyDemon.Drawing.IndependentText.CreateFontToFitHeight(String fontName, Single height, String text) vid Divelements.SkyDemon.Briefing.WeatherDrawing.DrawVfrConditionsImage(DrawingContext context, RectangleF bounds, VfrConditionsType conditions, Int32 opacity) vid Divelements.SkyDemon.Briefing.WeatherDrawing.<>c__DisplayClass23_0.<GetOrCreateConditionsImage>b__0(DrawingContext context, Rectangle bounds) vid Divelements.SkyDemon.Mapping.ExampleMapImages.CreateExampleImage(Int32 width, Int32 height, DrawPreviewDelegate d) vid Divelements.SkyDemon.Briefing.WeatherDrawing.GetOrCreateConditionsImage(VfrConditionsType conditions, Image& image) vid Divelements.SkyDemon.Briefing.WeatherHtmlOutput.GenerateWeatherConditionsStyle(VfrConditionsType type) vid Divelements.SkyDemon.Briefing.WeatherHtmlOutput.get_IconsCss() vid Divelements.SkyDemon.Briefing.AirfieldHtmlOutput2.GenerateListHtmlOutput(PlanningServices planningServices, TafMetarContainer tafMetarContainer, AirfieldLiveExtendedDataManager feedbackManager, Aerodrome[]& displayingAirfields) vid Divelements.SkyDemon.Briefing.AirfieldListHtmlOutputInteraction.GenerateHtml() vid Divelements.SkyDemon.Briefing.AirfieldsListScreen..ctor(ApplicationEnvironment environment) vid Divelements.SkyDemon.Briefing.PlateListwindow.AttachToEnvironment() vid Divelements.SkyDemon.UI.Environmentwindow.SetEnvironment(ApplicationEnvironment environment) vid Divelements.SkyDemon.frmMain.Form1_Load(Object sender, EventArgs e) vid System.EventHandler.Invoke(Object sender, EventArgs e) vid System.Windows.Forms.Form.OnLoad(EventArgs e) vid System.Windows.Forms.Form.OnCreateControl() vid System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible) vid System.Windows.Forms.Control.CreateControl() vid System.Windows.Forms.Control.WmShowWindow(Message& m) vid System.Windows.Forms.Control.WndProc(Message& m) vid System.Windows.Forms.Form.WmShowWindow(Message& m) vid System.Windows.Forms.Nativewindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Inlästa sammansättningar ************** mscorlib Sammansättningsversion: 4.0.0.0 Win32-version: 4.8.4300.0 built by: NET48REL1LAST_C CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll ---------------------------------------- SkyDemon Sammansättningsversion: 3.15.0.29226 Win32-version: CodeBase: file:///D:/Program%20Files%20(x86)/SkyDemon/SkyDemon.exe ---------------------------------------- Divelements.Aviation Sammansättningsversion: 3.15.0.29225 Win32-version: 3.15.0.0 CodeBase: file:///D:/Program%20Files%20(x86)/SkyDemon/Divelements.Aviation.DLL ---------------------------------------- System.Windows.Forms Sammansättningsversion: 4.0.0.0 Win32-version: 4.8.4270.0 built by: NET48REL1LAST_C CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll ---------------------------------------- System Sammansättningsversion: 4.0.0.0 Win32-version: 4.8.4300.0 built by: NET48REL1LAST_C CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- System.Drawing Sammansättningsversion: 4.0.0.0 Win32-version: 4.8.4084.0 built by: NET48REL1 CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll ---------------------------------------- Divelements.SandGrid Sammansättningsversion: 2.2.4.1 Win32-version: 2.2.4.1 CodeBase: file:///D:/Program%20Files%20(x86)/SkyDemon/Divelements.SandGrid.DLL ---------------------------------------- SandDock Sammansättningsversion: 3.0.6.1 Win32-version: 3.0.6.1 CodeBase: file:///D:/Program%20Files%20(x86)/SkyDemon/SandDock.DLL ---------------------------------------- TallComponents.PDF.Rasterizer Sammansättningsversion: 3.0.179.0 Win32-version: 3.0.179.0 CodeBase: file:///D:/Program%20Files%20(x86)/SkyDemon/TallComponents.PDF.Rasterizer.DLL ---------------------------------------- System.Configuration Sammansättningsversion: 4.0.0.0 Win32-version: 4.8.4190.0 built by: NET48REL1LAST_B CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll ---------------------------------------- System.Core Sammansättningsversion: 4.0.0.0 Win32-version: 4.8.4320.0 built by: NET48REL1LAST_C CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll ---------------------------------------- System.Xml Sammansättningsversion: 4.0.0.0 Win32-version: 4.8.4084.0 built by: NET48REL1 CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll ---------------------------------------- Divelements.Mapping Sammansättningsversion: 3.15.0.29225 Win32-version: 3.15.0.0 CodeBase: file:///D:/Program%20Files%20(x86)/SkyDemon/Divelements.Mapping.DLL ---------------------------------------- System.Speech Sammansättningsversion: 4.0.0.0 Win32-version: 4.8.4200.0 built by: NET48REL1LAST_C CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Speech/v4.0_4.0.0.0__31bf3856ad364e35/System.Speech.dll ---------------------------------------- mscorlib.resources Sammansättningsversion: 4.0.0.0 Win32-version: 4.8.4084.0 built by: NET48REL1 CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/mscorlib.resources/v4.0_4.0.0.0_sv_b77a5c561934e089/mscorlib.resources.dll ---------------------------------------- Microsoft.mshtml Sammansättningsversion: 7.0.3300.0 Win32-version: 7.0.3300.0 CodeBase: file:///C:/WINDOWS/assembly/GAC/Microsoft.mshtml/7.0.3300.0__b03f5f7f11d50a3a/Microsoft.mshtml.dll ---------------------------------------- System.Windows.Forms.resources Sammansättningsversion: 4.0.0.0 Win32-version: 4.8.4084.0 built by: NET48REL1 CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms.resources/v4.0_4.0.0.0_sv_b77a5c561934e089/System.Windows.Forms.resources.dll ---------------------------------------- System.Web Sammansättningsversion: 4.0.0.0 Win32-version: 4.8.4330.0 built by: NET48REL1LAST_B CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_64/System.Web/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Web.dll ----------------------------------------
************** JIT-felsökning ************** För att aktivera JIT-felsökning (just-in-time ) måste .config-filen för det här tillämpningsprogrammet eller datorn (machine.config) ha jitDebugging-värdet angivet i avsnittet system.windows.forms. Tillämpningsprogrammet måste också vara kompilerat med felsökning aktiverat.
Till exempel:
<configuration> <system.windows.forms jitDebugging="true" /> </configuration>
När JIT-felsökning är aktiverad kommer alla undantag som inte hanteras att skickas till JIT-felsökningsprogrammet som är registrerat på datorn snarare än att hanteras av den här dialogrutan.
marco@p3flyers.ch
Visits: 9
+xHi, after upgrading to the latest version 3.15.0.0 on PC i get the following errormessage when starting SkyDemon. Any suggestion what might be wrong? br // björn
Till exempel:
Visits: 32K
The same happened to me, but I clicked 'Continue' and it started OK.
After closing and restarting it, it worked fine without the error.
marco@p3flyers.ch
Visits: 9
+xThe same happened to me, but I clicked 'Continue' and it started OK.
After closing and restarting it, it worked fine without the error. I get the same thing. Despite rebooting. Unable to download maps
pilot-byom
Visits: 388
I did update Skydemon PC Plan recently and had no problems at all (using Windows10, 64bit, Version 20H2).
StefanSD
Visits: 0
Same here, even did a reinstall of SD but same error occurs. Still it *seems* to start if you "cancel" the error but then functionality is missing such as display of the route, remembering the currently planned route after restarting the software, clicking on aerodrome information pops up the error again and you don't get the info box with the AD info, ...
So its basically unusable
Does anybody know if there is a way to download an older version until the problem is fixed? On the download page it seems you can only access the most recent release.
pilot-byom
Visits: 388
Am I reading correct, this machine is running DotNET V4.0 ? Maybe that is in need of an update, mine is on DotNET V4.8.
Wasn't that the area where the unofficial Mac port was also struggling once?
Posts: 8.3K,
Visits: 10K
We've posted a beta this morning which we think will resolve the bug:
Once we've had a few people confirm it works for them we'll update the published version.
George Reid
Visits: 1.6K
+xAm I reading correct, this machine is running DotNET V4.0 ? Maybe that is in need of an update, mine is on DotNET V4.8.
Wasn't that the area where the unofficial Mac port was also struggling once? I too have had no problems since installing the latest version.
My PC is running DotNet Version 4.8
George E A Reid Ipad Mini 5, IOS 14.4, SD 3.15.0.288 PC(Win 10, Version 19041.804) SD 3.15.0.0
StefanSD
Visits: 0
+xWe've posted a beta this morning which we think will resolve the bug:
Once we've had a few people confirm it works for them we'll update the published version. I can give it a try in the late evening and report back here.
