Error after upgrading to 3.15.0.0
bjornbostrom
b
Posts: 5, Visits: 52
Hi, after upgrading to the latest version 3.15.0.0 on PC i get the following errormessage when starting SkyDemon. Any suggestion what might be wrong?
br // björn
Microsoft .NET Framework Exception
System.InvalidOperationException: Åtgärden är ogiltig på grund av objektets aktuella tillstånd.
 vid Divelements.SkyDemon.Drawing.IndependentText.CreateMeasurementGraphics()
 vid Divelements.SkyDemon.Drawing.IndependentText.CreateFontToFitHeight(String fontName, Single height, String text)
 vid Divelements.SkyDemon.Briefing.WeatherDrawing.DrawVfrConditionsImage(DrawingContext context, RectangleF bounds, VfrConditionsType conditions, Int32 opacity)
 vid Divelements.SkyDemon.Briefing.WeatherDrawing.<>c__DisplayClass23_0.<GetOrCreateConditionsImage>b__0(DrawingContext context, Rectangle bounds)
 vid Divelements.SkyDemon.Mapping.ExampleMapImages.CreateExampleImage(Int32 width, Int32 height, DrawPreviewDelegate d)
 vid Divelements.SkyDemon.Briefing.WeatherDrawing.GetOrCreateConditionsImage(VfrConditionsType conditions, Image& image)
 vid Divelements.SkyDemon.Briefing.WeatherHtmlOutput.GenerateWeatherConditionsStyle(VfrConditionsType type)
 vid Divelements.SkyDemon.Briefing.WeatherHtmlOutput.get_IconsCss()
 vid Divelements.SkyDemon.Briefing.AirfieldHtmlOutput2.GenerateListHtmlOutput(PlanningServices planningServices, TafMetarContainer tafMetarContainer, AirfieldLiveExtendedDataManager feedbackManager, Aerodrome[]& displayingAirfields)
 vid Divelements.SkyDemon.Briefing.AirfieldListHtmlOutputInteraction.GenerateHtml()
 vid Divelements.SkyDemon.Briefing.AirfieldsListScreen..ctor(ApplicationEnvironment environment)
 vid Divelements.SkyDemon.Briefing.PlateListwindow.AttachToEnvironment()
 vid Divelements.SkyDemon.UI.Environmentwindow.SetEnvironment(ApplicationEnvironment environment)
 vid Divelements.SkyDemon.frmMain.Form1_Load(Object sender, EventArgs e)
 vid System.EventHandler.Invoke(Object sender, EventArgs e)
 vid System.Windows.Forms.Form.OnLoad(EventArgs e)
 vid System.Windows.Forms.Form.OnCreateControl()
 vid System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
 vid System.Windows.Forms.Control.CreateControl()
 vid System.Windows.Forms.Control.WmShowWindow(Message& m)
 vid System.Windows.Forms.Control.WndProc(Message& m)
 vid System.Windows.Forms.Form.WmShowWindow(Message& m)
 vid System.Windows.Forms.Nativewindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Inlästa sammansättningar **************
mscorlib
  Sammansättningsversion: 4.0.0.0
  Win32-version: 4.8.4300.0 built by: NET48REL1LAST_C
  CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
SkyDemon
  Sammansättningsversion: 3.15.0.29226
  Win32-version:
  CodeBase: file:///D:/Program%20Files%20(x86)/SkyDemon/SkyDemon.exe
Divelements.Aviation
  Sammansättningsversion: 3.15.0.29225
  Win32-version: 3.15.0.0
  CodeBase: file:///D:/Program%20Files%20(x86)/SkyDemon/Divelements.Aviation.DLL
  Win32-version: 4.8.4270.0 built by: NET48REL1LAST_C
  CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
  CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Drawing
  Win32-version: 4.8.4084.0 built by: NET48REL1
  CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
Divelements.SandGrid
  Sammansättningsversion: 2.2.4.1
  Win32-version: 2.2.4.1
  CodeBase: file:///D:/Program%20Files%20(x86)/SkyDemon/Divelements.SandGrid.DLL
SandDock
  Sammansättningsversion: 3.0.6.1
  Win32-version: 3.0.6.1
  CodeBase: file:///D:/Program%20Files%20(x86)/SkyDemon/SandDock.DLL
TallComponents.PDF.Rasterizer
  Sammansättningsversion: 3.0.179.0
  Win32-version: 3.0.179.0
  CodeBase: file:///D:/Program%20Files%20(x86)/SkyDemon/TallComponents.PDF.Rasterizer.DLL
System.Configuration
  Win32-version: 4.8.4190.0 built by: NET48REL1LAST_B
  CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Core
  Win32-version: 4.8.4320.0 built by: NET48REL1LAST_C
  CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System.Xml
  CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
Divelements.Mapping
  CodeBase: file:///D:/Program%20Files%20(x86)/SkyDemon/Divelements.Mapping.DLL
System.Speech
  Win32-version: 4.8.4200.0 built by: NET48REL1LAST_C
  CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Speech/v4.0_4.0.0.0__31bf3856ad364e35/System.Speech.dll
mscorlib.resources
  CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/mscorlib.resources/v4.0_4.0.0.0_sv_b77a5c561934e089/mscorlib.resources.dll
Microsoft.mshtml
  Sammansättningsversion: 7.0.3300.0
  Win32-version: 7.0.3300.0
  CodeBase: file:///C:/WINDOWS/assembly/GAC/Microsoft.mshtml/7.0.3300.0__b03f5f7f11d50a3a/Microsoft.mshtml.dll
System.Windows.Forms.resources
  CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms.resources/v4.0_4.0.0.0_sv_b77a5c561934e089/System.Windows.Forms.resources.dll
System.Web
  Win32-version: 4.8.4330.0 built by: NET48REL1LAST_B
  CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_64/System.Web/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Web.dll
************** JIT-felsökning **************
För att aktivera JIT-felsökning (just-in-time ) måste .config-filen för det här
tillämpningsprogrammet eller datorn (machine.config) ha
jitDebugging-värdet angivet i avsnittet system.windows.forms.
Tillämpningsprogrammet måste också vara kompilerat med felsökning
aktiverat.
Till exempel:
<configuration>
</configuration>
När JIT-felsökning är aktiverad kommer alla undantag som inte hanteras
att skickas till JIT-felsökningsprogrammet som är registrerat på datorn
snarare än att hanteras av den här dialogrutan.
marco@p3flyers.ch
m
Posts: 2, Visits: 9
bjornbostrom - 2/16/2021 2:33:38 PM
br // björn
mscorlib
SkyDemon
  Win32-version:
System
System.Drawing
SandDock
System.Core
System.Xml
Divelements.Mapping
System.Speech
mscorlib.resources
Microsoft.mshtml
System.Web
aktiverat.
Till exempel:
<configuration>
</configuration>
Posts: 647, Visits: 31K
The same happened to me, but I clicked 'Continue' and it started OK.
After closing and restarting it, it worked fine without the error.
marco@p3flyers.ch
m
Posts: 2, Visits: 9
grahamb - 2/16/2021 3:24:37 PM
I get the same thing. Despite rebooting. Unable to download maps
I did update Skydemon PC Plan recently and had no problems at all (using Windows10, 64bit, Version 20H2).
Edited 2/16/2021 9:07:56 PM by pilot-byom
StefanSD
S
Posts: 3, Visits: 0
Same here, even did a reinstall of SD but same error occurs. Still it *seems* to start if you "cancel" the error but then functionality is missing such as display of the route, remembering the currently planned route after restarting the software, clicking on aerodrome information pops up the error again and you don't get the info box with the AD info, ...
So its basically unusable Sad
Does anybody know if there is a way to download an older version until the problem is fixed? On the download page it seems you can only access the most recent release.
Am I reading correct, this machine is running DotNET V4.0 ?
Maybe that is in need of an update, mine is on DotNET V4.8.
Wasn't that the area where the unofficial Mac port was also struggling once?
Edited 2/17/2021 9:13:45 AM by pilot-byom
We've posted a beta this morning which we think will resolve the bug:
Once we've had a few people confirm it works for them we'll update the published version.
George Reid
George Reid
Posts: 113, Visits: 1.6K
pilot-byom - 2/17/2021 8:46:40 AM
I too have had no problems since installing the latest version.
My PC is running DotNet Version 4.8
George E A Reid
StefanSD
S
Posts: 3, Visits: 0
Tim Dawson - 2/17/2021 11:49:59 AM
I can give it a try in the late evening and report back here.
