Error after upgrading to 3.15.0.0
bjornbostrom
b
Posts: 5, Visits: 52
Hi, after upgrading to the latest version 3.15.0.0 on PC i get the following errormessage when starting SkyDemon. Any suggestion what might be wrong?
br // björn
Microsoft .NET Framework Exception
System.InvalidOperationException: Åtgärden är ogiltig på grund av objektets aktuella tillstånd.
 vid Divelements.SkyDemon.Drawing.IndependentText.CreateMeasurementGraphics()
 vid Divelements.SkyDemon.Drawing.IndependentText.CreateFontToFitHeight(String fontName, Single height, String text)
 vid Divelements.SkyDemon.Briefing.WeatherDrawing.DrawVfrConditionsImage(DrawingContext context, RectangleF bounds, VfrConditionsType conditions, Int32 opacity)
 vid Divelements.SkyDemon.Briefing.WeatherDrawing.<>c__DisplayClass23_0.<GetOrCreateConditionsImage>b__0(DrawingContext context, Rectangle bounds)
 vid Divelements.SkyDemon.Mapping.ExampleMapImages.CreateExampleImage(Int32 width, Int32 height, DrawPreviewDelegate d)
 vid Divelements.SkyDemon.Briefing.WeatherDrawing.GetOrCreateConditionsImage(VfrConditionsType conditions, Image& image)
 vid Divelements.SkyDemon.Briefing.WeatherHtmlOutput.GenerateWeatherConditionsStyle(VfrConditionsType type)
 vid Divelements.SkyDemon.Briefing.WeatherHtmlOutput.get_IconsCss()
 vid Divelements.SkyDemon.Briefing.AirfieldHtmlOutput2.GenerateListHtmlOutput(PlanningServices planningServices, TafMetarContainer tafMetarContainer, AirfieldLiveExtendedDataManager feedbackManager, Aerodrome[]& displayingAirfields)
 vid Divelements.SkyDemon.Briefing.AirfieldListHtmlOutputInteraction.GenerateHtml()
 vid Divelements.SkyDemon.Briefing.AirfieldsListScreen..ctor(ApplicationEnvironment environment)
 vid Divelements.SkyDemon.Briefing.PlateListwindow.AttachToEnvironment()
 vid Divelements.SkyDemon.UI.Environmentwindow.SetEnvironment(ApplicationEnvironment environment)
 vid Divelements.SkyDemon.frmMain.Form1_Load(Object sender, EventArgs e)
 vid System.EventHandler.Invoke(Object sender, EventArgs e)
 vid System.Windows.Forms.Form.OnLoad(EventArgs e)
 vid System.Windows.Forms.Form.OnCreateControl()
 vid System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
 vid System.Windows.Forms.Control.CreateControl()
 vid System.Windows.Forms.Control.WmShowWindow(Message& m)
 vid System.Windows.Forms.Control.WndProc(Message& m)
 vid System.Windows.Forms.Form.WmShowWindow(Message& m)
 vid System.Windows.Forms.Nativewindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Inlästa sammansättningar **************
mscorlib
  Sammansättningsversion: 4.0.0.0
  Win32-version: 4.8.4300.0 built by: NET48REL1LAST_C
  CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
SkyDemon
  Sammansättningsversion: 3.15.0.29226
  Win32-version:
  CodeBase: file:///D:/Program%20Files%20(x86)/SkyDemon/SkyDemon.exe
Divelements.Aviation
  Sammansättningsversion: 3.15.0.29225
  Win32-version: 3.15.0.0
  CodeBase: file:///D:/Program%20Files%20(x86)/SkyDemon/Divelements.Aviation.DLL
  Win32-version: 4.8.4270.0 built by: NET48REL1LAST_C
  CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
  CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Drawing
  Win32-version: 4.8.4084.0 built by: NET48REL1
  CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
Divelements.SandGrid
  Sammansättningsversion: 2.2.4.1
  Win32-version: 2.2.4.1
  CodeBase: file:///D:/Program%20Files%20(x86)/SkyDemon/Divelements.SandGrid.DLL
SandDock
  Sammansättningsversion: 3.0.6.1
  Win32-version: 3.0.6.1
  CodeBase: file:///D:/Program%20Files%20(x86)/SkyDemon/SandDock.DLL
TallComponents.PDF.Rasterizer
  Sammansättningsversion: 3.0.179.0
  Win32-version: 3.0.179.0
  CodeBase: file:///D:/Program%20Files%20(x86)/SkyDemon/TallComponents.PDF.Rasterizer.DLL
System.Configuration
  Win32-version: 4.8.4190.0 built by: NET48REL1LAST_B
  CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Core
  Win32-version: 4.8.4320.0 built by: NET48REL1LAST_C
  CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System.Xml
  CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
Divelements.Mapping
  CodeBase: file:///D:/Program%20Files%20(x86)/SkyDemon/Divelements.Mapping.DLL
System.Speech
  Win32-version: 4.8.4200.0 built by: NET48REL1LAST_C
  CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Speech/v4.0_4.0.0.0__31bf3856ad364e35/System.Speech.dll
mscorlib.resources
  CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/mscorlib.resources/v4.0_4.0.0.0_sv_b77a5c561934e089/mscorlib.resources.dll
Microsoft.mshtml
  Sammansättningsversion: 7.0.3300.0
  Win32-version: 7.0.3300.0
  CodeBase: file:///C:/WINDOWS/assembly/GAC/Microsoft.mshtml/7.0.3300.0__b03f5f7f11d50a3a/Microsoft.mshtml.dll
System.Windows.Forms.resources
  CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms.resources/v4.0_4.0.0.0_sv_b77a5c561934e089/System.Windows.Forms.resources.dll
System.Web
  Win32-version: 4.8.4330.0 built by: NET48REL1LAST_B
  CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_64/System.Web/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Web.dll
************** JIT-felsökning **************
För att aktivera JIT-felsökning (just-in-time ) måste .config-filen för det här
tillämpningsprogrammet eller datorn (machine.config) ha
jitDebugging-värdet angivet i avsnittet system.windows.forms.
Tillämpningsprogrammet måste också vara kompilerat med felsökning
aktiverat.
Till exempel:
<configuration>
</configuration>
När JIT-felsökning är aktiverad kommer alla undantag som inte hanteras
att skickas till JIT-felsökningsprogrammet som är registrerat på datorn
snarare än att hanteras av den här dialogrutan.
marco@p3flyers.ch
m
Posts: 2, Visits: 9
bjornbostrom - 2/16/2021 2:33:38 PM
br // björn
mscorlib
SkyDemon
  Win32-version:
System
System.Drawing
SandDock
System.Core
System.Xml
Divelements.Mapping
System.Speech
mscorlib.resources
Microsoft.mshtml
System.Web
aktiverat.
Till exempel:
<configuration>
</configuration>
marco@p3flyers.ch - 2/16/2021 3:20:47 PM
grahamb - 2/16/2021 3:24:37 PM
marco@p3flyers.ch - 2/16/2021 3:32:19 PM
pilot-byom - 2/16/2021 8:45:55 PM
StefanSD - 2/17/2021 6:26:59 AM
pilot-byom - 2/17/2021 8:46:40 AM
GEAR - 2/17/2021 11:58:12 AM
Tim Dawson - 2/17/2021 11:49:59 AM
StefanSD - 2/17/2021 12:06:52 PM
florianj - 2/22/2021 9:37:41 AM
smokescreen - 2/17/2021 12:40:05 PM
StefanSD - 2/17/2021 6:13:52 PM
Fred4680 - 2/17/2021 7:31:28 PM
             Is that iOS or Android?
Tim Dawson - 2/18/2021 10:12:59 AM
Fred4680 - 2/18/2021 10:30:27 AM
             Thanks, we'll look into it.
Tim Dawson - 2/19/2021 10:12:45 AM
