Size of higher/lower value
Maverix
M
Too Much Forum (823 reputation)Too Much Forum (823 reputation)Too Much Forum (823 reputation)Too Much Forum (823 reputation)Too Much Forum (823 reputation)Too Much Forum (823 reputation)Too Much Forum (823 reputation)Too Much Forum (823 reputation)Too Much Forum (823 reputation)
Posts: 53, Visits: 14
is there an option to adjust the size of the higher/lower value of (bearing less) targets?
Sometimes it's very hard to read this value during flight.
Thx
efrenken
efrenken
Posts: 265, Visits: 3.5K
Same here. Sometimes my head-down-time is irresponsibly long in order to decipher those values.
Eric
Yes, that text size is adjustable along with the other map fonts, under Mapping. It's the same size as larger airfields, so if you can read the names of airfields, you should be able to read the level text.
Maverix
M
Tim Dawson - 7/22/2020 8:49:29 AM
Maybe you can write the bearingless target information in a box with white background?
It's hard to find and to read!
efrenken
efrenken
Maverix - 11/9/2020 2:21:25 PM
So true!
