difference using PilotAware versus GDL90 as the source does?
marioair
m
Posts: 166, Visits: 1
What does Skydemon do differently using PilotAware versus GDL90 as the Navigation source?
I have PilotAware setup as a wifi. I've noticed I can get SD to work either using the PaW option or GDL90. Is there a loss of functionality if choosing one or the other?
The reason for the question is that I also have an ADL Weather unit which can transmit weather using GDL. So if i select GDL as the nav source in SD will I loose anything from the PaW capabilities?
TimT
TimT
Posts: 98, Visits: 92
marioair - 5/25/2020 10:32:09 AM
Marioair, you may get an authoritative answer without delay if you asked the same question in the PAW Forum.
marioair
m
TimT - 6/17/2020 3:27:16 PM
Hi Tim
It was more a question of why does SD have an explict option for PilotAware as opposed to generic GDL devices :-)
pilot-byom
p
Posts: 323, Visits: 388
Pilotaware is a proprietary private product, such as Flarm, and GDL90 is a protocol originally published by Garmin. Apples and Oranges? You can let Flarm or Pilotaware send via GDL90 without some special traffic features, if you need more compatibility or function beyond payed subscription (at least at Flarm).
marioair
m
MarkusM - 6/17/2020 4:04:37 PM
AFAIK PaW doesnt transmit data to SD over a proprietary format - again that's something the SD forum should be able to confirm?
pilot-byom
p
marioair - 6/17/2020 4:11:20 PM
LMGTFY - https://pilotaware.com/wp-content/uploads/2017/03/Protocol.pdf
marioair
m
MarkusM - 6/17/2020 5:48:05 PM
Doesnt answer the question.......is that the protocol that SD accept an processes? So SD have written code to process that format? My understanding from the PaW team is that it broadcasts GDL and Flarm - for the purposes of display on navigation devices. The p3i is broadcast for other paw devices to receive.
The PilotAware option within SkyDemon accepts FLARM protocol but over a UDP connection rather than the traditional TCP.
marioair
m
Tim Dawson - 6/19/2020 8:23:36 AM
Thank Tim, that makes more sense! I've had several thread with fairly good traffic to help PaW and SD intergrate with a more standard approach. At you request the summarised thread is here
with the original thread having way more interest
