What does Skydemon do differently using PilotAware versus GDL90 as the Navigation source?
I have PilotAware setup as a wifi. I've noticed I can get SD to work either using the PaW option or GDL90. Is there a loss of functionality if choosing one or the other?
The reason for the question is that I also have an ADL Weather unit which can transmit weather using GDL. So if i select GDL as the nav source in SD will I loose anything from the PaW capabilities?
