Finger Friendly SIP
Runways
Runways
Posts: 309, Visits: 1.6K
Hello again Stevelup,
Can I ask if it is a good idea to add a dash key (-) function to the key board. Just thinking in terms of Route title writing eg: writing egnt-egpn, instead of egnt to egpn. Also would it be better to have all in upper case? Just a thought. It is an excellent keyboard that can be added in a very much simplified way.
Very Newbytheway
DurhamTeaseAirport
pink leader
pink leader
Too Much Forum (52K reputation)Too Much Forum (52K reputation)Too Much Forum (52K reputation)Too Much Forum (52K reputation)Too Much Forum (52K reputation)Too Much Forum (52K reputation)Too Much Forum (52K reputation)Too Much Forum (52K reputation)Too Much Forum (52K reputation)
Posts: 519, Visits: 2K
Anyone tried this with a Navigon 8410. This requires a version of Miopocket to be on the card.
Am reluctant to be the guinea pig as we are just off on a trip.
D
Posts: 593, Visits: 4.9K
I'm not sure whether it will work on the Navigon. I know there are no SIP's loaded on there - if that's all the problem is, then it'll work.
Unfortunately, I suspect the issue is that the CE image was built with no SIP support in which case it won't work full stop.
If someone at some point wants to send me a Navigon unit, I'll try and get it working - but it might be impossible.
Runways (31/05/2011)
I can easily force it into upper case. There isn't room on the current design for a dash key. Could I get rid of the Enter key? It doesn't really do anything useful unless I've missed something?
pink leader
pink leader
Steve
Re Navigon, I can let you try mine but not for 10 days or so  .. not sure where you are  .. I am in Yorkshire  .. anyone nearer?
I also tried on the Navsgo unit and it did not work for me. Anyone else? On this unit one cannot get to the Windows Desktop or Explorer. Mean anything?
Anyway, well done Steve. Any way that Tim can take it on from here and incorporate?
D
Runways
Runways
I think you are right Steve, I don't know if the enter key is needed or not, but it has such a major function, may be too major to do without (queen on chess board). Would splitting the space-bar into two keys (2/3 space bar 1/3 dash) be a reasonable option?
It is a very nice keyboard, installation is easy, works with WinCE 5 & 6 flawlessly and extremely useful in flight. Well done.
Very Newbytheway
DurhamTeaseAirport
Edited 5/31/2011 8:10:06 PM by Runways
Tony
Tony
Posts: 33, Visits: 255
Hi guys
David. I've tried to get this to work on my 7inch Navsgo unit but with NO luck like you Maybe it could be something that I'm/we are doing wrong?
Tony
Max_UK
Max_UK
Too Much Forum (6.9K reputation)Too Much Forum (6.9K reputation)Too Much Forum (6.9K reputation)Too Much Forum (6.9K reputation)Too Much Forum (6.9K reputation)Too Much Forum (6.9K reputation)Too Much Forum (6.9K reputation)Too Much Forum (6.9K reputation)Too Much Forum (6.9K reputation)
Posts: 66, Visits: 2.9K
Thanks Steve, The major problem of the keyboard on high resolution devices seems to be solved.
Also, on my winCE 6 480 x 272 4.3" gps, the autoscript works perfectly & the 480 screen is automatically loaded.
On my two WinCE 5 gps units, I can't get the skysip480.dll to register using regsvrce.exe. Also tried manually importing the  registry keys from the WinCE 6 unit but as yet, no success. The "AutoSelectSIP.exe" also throws up errors.
Guess it's just a WinCE 5 issue. Lots about it on the net but nobody seems to have the definitive answer. BigGrin
For those of you having problems, are you using WinCE 5 or 6?
Regards,
Max.
pink leader
pink leader
Tony
At Steve's request, I am sending him a couple of files that will enable him to see whether it shd run or not  .. 1 file for 8410 & 1 for Navsgo.
I will report back.
D
Tony
Tony
Thanks David. Steve I meant to say in my last post Thanks for all the hard work you have put in.
Tony
Edited 5/31/2011 10:09:21 PM by Tony
