User manual PDF name change
Massimo Belloni
Massimo Belloni
Too Much Forum (985 reputation)Too Much Forum (985 reputation)Too Much Forum (985 reputation)Too Much Forum (985 reputation)Too Much Forum (985 reputation)Too Much Forum (985 reputation)Too Much Forum (985 reputation)Too Much Forum (985 reputation)Too Much Forum (985 reputation)
Posts: 35, Visits: 6.5K
I usually keep a copy of the user manual locally on my devices (you never know...).
The file name, when saved, is "manual.pdf", which is a quite generic name which does not help to find it easily among other files in a directory, and easy to be mistaken with other files.
What about changing the file name to something more explicative, i.e. like "Skydemon_manual.pdf"?
Massimo Belloni
Edited 10/20/2019 10:39:15 AM by Massimo Belloni
efrenken
efrenken
Posts: 265, Visits: 3.5K
Massimo Belloni - 10/20/2019 10:38:50 AM
Massimo,
You can rename the local file on your device anytime.
Eric
Edited 10/20/2019 11:55:22 AM by efrenken
Massimo Belloni
Massimo Belloni
efrenken - 10/20/2019 11:54:49 AM
Massimo,
Eric
That's  what I do every time.
IMHO usually filenames (when saving them) already have a meaningful name by default, not needing to be renamed every time.
Massimo Belloni
Edited 10/20/2019 1:16:06 PM by Massimo Belloni
Since we save manual.pdf in the SkyDemon folder, it seems like a sensible name to me. I do not believe there is sufficient reason for us to change it at this point.
Massimo Belloni
Massimo Belloni
Tim Dawson - 10/23/2019 2:18:28 PM
OK, I understand.
Let's anyway see the issue in a different mode:
  • Windows: looking for help from inside the application leads you to open the link to the documentation webpage, where every time you have to download the file. Not very practical, but at lest you're sure that you're reading the last version. Working offline it's not anyway a big deal: just download previously the file  and rename it to a more useful one (just a bit boring), so to avoid confusing it with other files.
  • iOS: (more important in flight, of course). The help goes directly to the manual file, but the native pdf reader miss the Search function*, which is quite useful (especially in flight), instead that trying to find the right chapter in the index, go there and find what you're looking for.  Having the Search function implemented would be very welcome (don't know how it does work in Android, sorry).
What do you think about?
* = at least, I did not find the Search function: if it is present, please correct me.
Massimo Belloni
Edited 10/25/2019 10:50:58 AM by Massimo Belloni
To my knowledge, the native iOS PDF reader doesn't include a search function. You're free to install other PDF readers and export any PDF from the native reader into those to view them.
