+x Massimo Belloni - 10/20/2019 10:38:50 AMI usually keep a copy of the user manual locally on my devices (you never know...).The file name, when saved, is "manual.pdf", which is a quite generic name which does not help to find it easily among other files in a directory, and easy to be mistaken with other files.What about changing the file name to something more explicative, i.e. like "Skydemon_manual.pdf"?
+x efrenken - 10/20/2019 11:54:49 AM+x Massimo Belloni - 10/20/2019 10:38:50 AMI usually keep a copy of the user manual locally on my devices (you never know...).The file name, when saved, is "manual.pdf", which is a quite generic name which does not help to find it easily among other files in a directory, and easy to be mistaken with other files.What about changing the file name to something more explicative, i.e. like "Skydemon_manual.pdf"?Massimo,You can rename the local file on your device anytime.Eric
+x Tim Dawson - 10/23/2019 2:18:28 PMSince we save manual.pdf in the SkyDemon folder, it seems like a sensible name to me. I do not believe there is sufficient reason for us to change it at this point.
