SkyDemon and SkyEcho 2
Massimo Belloni
Massimo Belloni
Posts: 35, Visits: 6.5K
b3nn0 reselase is absolutely fantastic and works flawlessy. Currently I'm using 1.5b2-eu004 (last official release as for today).
Very good job b3enn0!
Massimo Belloni
Yes, I meant its ADS/B output too. We have never seen anything to support the notion that it isn't allowed in Europe. It's a standard aviation message being transmitted on a standard aviation frequency.
Alf
Alf
Too Much Forum (260 reputation)Too Much Forum (260 reputation)Too Much Forum (260 reputation)Too Much Forum (260 reputation)Too Much Forum (260 reputation)Too Much Forum (260 reputation)Too Much Forum (260 reputation)Too Much Forum (260 reputation)Too Much Forum (260 reputation)
Posts: 22, Visits: 20
Tim Dawson - 7/9/2019 9:55:57 AM
I agree, I haven´t seen such a law either. The SE2 manual irritates me, see attached.
BR,
Alf
A shame, they are rather shooting themselves in the foot there.
tmmtaha75
t
Forum Newbie (9 reputation)Forum Newbie (9 reputation)Forum Newbie (9 reputation)Forum Newbie (9 reputation)Forum Newbie (9 reputation)Forum Newbie (9 reputation)Forum Newbie (9 reputation)Forum Newbie (9 reputation)Forum Newbie (9 reputation)
Posts: 1, Visits: 0
Alf - 6/5/2019 8:07:36 PM
TouchTheSky - 6/5/2019 8:00:05 PM
Alf - 6/5/2019 7:53:09 PM
TouchTheSky - 6/5/2019 6:32:29 PM
tnowak - 6/5/2019 8:04:40 AM
Hi Alf,
I also fly a vintage aircraft with no electrical system.
However I do have a Trig TT21 transponder with ADS-B out connection, Trig TY91 8.33 VHF radio and also a Horis 80 AHRS.
I power this equipment using a 12V 5.2AH Li-Ion battery which lasts at least 8 flying hours between re-charges.
So it is possible to be equipped with a transponders etc. without a full aircraft electrical system.
I am still undecided which way to go with having an electronic conspicuity receiver capability.
I like the SE2 but it can only detect ADS-B and FLARM. Also I would need to disable the SE2 Mode-S transmissions as I have a transponder.
PAW is on the list and will be interesting to see how the new MLAT capability works.
Tony
I think it is worth mentioning here that a Stratux Europe version has now been created:
Thanks for the hint, I have never heard something about Stratux. Sounds interesting. Is there an advantage compared to SkyEcho 2?
Thanks for clarification.
BR
Well, BoM (bill of material) is less than € 150, it receives ADS-B and FLARM and connects to all major EFBs including SD over GDL90 protocol. Several sources offer ready-to-fly versions for € 279 or DIY kits for € 225
Furthermore there are a couple of folks (including myself) that maintain the code and develop it further.
Thank you for the quick reply. You folks are great, really like this. My question was more towards: Does it have the same functionality as SkyEcho 2 with the FEB 2019 Firmware, ADS-B in/out, Flarm AND Mode S/C bearingless reception?
Cheers,
Alf
Sky Echo 2 does NOT have the ability to show bearingless targets. They scrapped that trial feature.
Alf
Alf
tmmtaha75 - 9/21/2019 10:59:08 AM
Hi Alf,
Tony
BR
Cheers,
Alf
Not if you stay with firmware from 2/8/2019 Cool
EHOW flyer
EHOW flyer
Posts: 66, Visits: 215
I use the ADSB out everytime I fly with aircraft without this possibility. Regardless if this is permitted or not, no one will check this! If all SE2 owners do the same, it will be more crowded on de SD display, and safer in the air.
Once I forgot the change the HEX and REG in SE2, so later on I discovered my flight in Flightradar24 tracked as 2 flights. The MLAT from the aircraft transponder was a very short line compared to the ADSB track, this was tracked almost from takeoff till landing.Smile
