+x Tim Dawson - 7/9/2019 9:55:57 AMYes, I meant its ADS/B output too. We have never seen anything to support the notion that it isn't allowed in Europe. It's a standard aviation message being transmitted on a standard aviation frequency.
+x Alf - 6/5/2019 8:07:36 PM+x TouchTheSky - 6/5/2019 8:00:05 PM+x Alf - 6/5/2019 7:53:09 PM+x TouchTheSky - 6/5/2019 6:32:29 PM+x tnowak - 6/5/2019 8:04:40 AMHi Alf,I also fly a vintage aircraft with no electrical system.However I do have a Trig TT21 transponder with ADS-B out connection, Trig TY91 8.33 VHF radio and also a Horis 80 AHRS.I power this equipment using a 12V 5.2AH Li-Ion battery which lasts at least 8 flying hours between re-charges.So it is possible to be equipped with a transponders etc. without a full aircraft electrical system.I am still undecided which way to go with having an electronic conspicuity receiver capability.I like the SE2 but it can only detect ADS-B and FLARM. Also I would need to disable the SE2 Mode-S transmissions as I have a transponder.PAW is on the list and will be interesting to see how the new MLAT capability works.TonyI think it is worth mentioning here that a Stratux Europe version has now been created:https://github.com/b3nn0/stratuxThanks for the hint, I have never heard something about Stratux. Sounds interesting. Is there an advantage compared to SkyEcho 2?Thanks for clarification.BRWell, BoM (bill of material) is less than € 150, it receives ADS-B and FLARM and connects to all major EFBs including SD over GDL90 protocol. Several sources offer ready-to-fly versions for € 279 or DIY kits for € 225Furthermore there are a couple of folks (including myself) that maintain the code and develop it further.Thank you for the quick reply. You folks are great, really like this. My question was more towards: Does it have the same functionality as SkyEcho 2 with the FEB 2019 Firmware, ADS-B in/out, Flarm AND Mode S/C bearingless reception?Cheers,Alf
+x tmmtaha75 - 9/21/2019 10:59:08 AM+x Alf - 6/5/2019 8:07:36 PM+x TouchTheSky - 6/5/2019 8:00:05 PM+x Alf - 6/5/2019 7:53:09 PM+x TouchTheSky - 6/5/2019 6:32:29 PM+x tnowak - 6/5/2019 8:04:40 AMHi Alf,I also fly a vintage aircraft with no electrical system.However I do have a Trig TT21 transponder with ADS-B out connection, Trig TY91 8.33 VHF radio and also a Horis 80 AHRS.I power this equipment using a 12V 5.2AH Li-Ion battery which lasts at least 8 flying hours between re-charges.So it is possible to be equipped with a transponders etc. without a full aircraft electrical system.I am still undecided which way to go with having an electronic conspicuity receiver capability.I like the SE2 but it can only detect ADS-B and FLARM. Also I would need to disable the SE2 Mode-S transmissions as I have a transponder.PAW is on the list and will be interesting to see how the new MLAT capability works.TonyI think it is worth mentioning here that a Stratux Europe version has now been created:https://github.com/b3nn0/stratuxThanks for the hint, I have never heard something about Stratux. Sounds interesting. Is there an advantage compared to SkyEcho 2?Thanks for clarification.BRWell, BoM (bill of material) is less than € 150, it receives ADS-B and FLARM and connects to all major EFBs including SD over GDL90 protocol. Several sources offer ready-to-fly versions for € 279 or DIY kits for € 225Furthermore there are a couple of folks (including myself) that maintain the code and develop it further.Thank you for the quick reply. You folks are great, really like this. My question was more towards: Does it have the same functionality as SkyEcho 2 with the FEB 2019 Firmware, ADS-B in/out, Flarm AND Mode S/C bearingless reception?Cheers,AlfSky Echo 2 does NOT have the ability to show bearingless targets. They scrapped that trial feature.
