Portugal VFR Aerodrome Charts
miguel22
m
Too Much Forum (50 reputation)Too Much Forum (50 reputation)Too Much Forum (50 reputation)Too Much Forum (50 reputation)Too Much Forum (50 reputation)Too Much Forum (50 reputation)Too Much Forum (50 reputation)Too Much Forum (50 reputation)Too Much Forum (50 reputation)
Posts: 5, Visits: 0
Hello all,
Any possible dates/updates about when Portugal AIP and VFR Approach charts will be avaialble to purchase?
I really like this feature of putting the real vfr approach chart on the map as already happens with Switzerland for example. Do you know if this feature is possible if I have the pdf downloaded on my ipad and saved on SD?
Thanks.
Do we not already have these documents?
miguel22
m
Posts: 5, Visits: 0
Tim Dawson - 10/11/2018 11:10:59 AM
Hello Tim,
I have downloaded the Portuguese AIP however I cant put then on the MAP directly to follow exactly the path on the chart...
Any ideas ?
Thanks!
There may be a reason that they are not georeferenced. Please could you contact our customer support and ask them? They will be able to give you an answer, whereas I cannot.
miguel22
m
Posts: 5, Visits: 0
Hello Tim,
Yes sure no problem Should I send them email? Or through the app?
Thanks a lot!
Just email them from our website.
miguel22
m
Posts: 5, Visits: 0
Is there any plan to have more airports georeferenced? Because only the main airports allows to put the chart in the map.
Thank you.
Edited 10/22/2019 8:54:16 PM by miguel22
If you give a couple of examples of airfields whose charts are not georeferenced but where you believe they should be, we can comment on them specifically for you.
miguel22
m
Posts: 5, Visits: 0
Tim Dawson - 10/23/2019 2:16:38 PM
Hello Tim,
Should I send an email through your website?
Thanks for the answer.
Yes please, that would be very helpful.
