Portugal VFR Aerodrome Charts
miguel22
m
Posts: 5, Visits: 0
Hello all,
Any possible dates/updates about when Portugal AIP and VFR Approach charts will be avaialble to purchase?
I really like this feature of putting the real vfr approach chart on the map as already happens with Switzerland for example. Do you know if this feature is possible if I have the pdf downloaded on my ipad and saved on SD?
Thanks.
Do we not already have these documents?
miguel22
m
Posts: 5, Visits: 0
Tim Dawson - 10/11/2018 11:10:59 AM
Hello Tim,
I have downloaded the Portuguese AIP however I cant put then on the MAP directly to follow exactly the path on the chart...
Any ideas ?
Thanks!
There may be a reason that they are not georeferenced. Please could you contact our customer support and ask them? They will be able to give you an answer, whereas I cannot.
miguel22
m
Posts: 5, Visits: 0
Hello Tim,
Yes sure no problem Should I send them email? Or through the app?
Thanks a lot!
Just email them from our website.
miguel22
m
Posts: 5, Visits: 0
Is there any plan to have more airports georeferenced? Because only the main airports allows to put the chart in the map.
Thank you.
Edited 10/22/2019 8:54:16 PM by miguel22
If you give a couple of examples of airfields whose charts are not georeferenced but where you believe they should be, we can comment on them specifically for you.
miguel22
m
Posts: 5, Visits: 0
Tim Dawson - 10/23/2019 2:16:38 PM
Hello Tim,
Should I send an email through your website?
Thanks for the answer.
Yes please, that would be very helpful.
