IPhone - "Start new route" and "add to route" by tapping on Screen doesn´t work any more
mwitt
m
Too Much Forum (327 reputation)Too Much Forum (327 reputation)Too Much Forum (327 reputation)Too Much Forum (327 reputation)Too Much Forum (327 reputation)Too Much Forum (327 reputation)Too Much Forum (327 reputation)Too Much Forum (327 reputation)Too Much Forum (327 reputation)
Posts: 3, Visits: 0
Hey there!
// Actual configuration:‌
// SD version 3.8.5‌
// IPhone‌ 6s version 11.2‌
// IPad 4‌ WiFi+Cellular version 9.3.2
After updating my SD I´m not able to start a route by tapping on the screen in planning mode any more. I tried different ways and figured out, that only if I go to flying mode I´m able to create a leg by tapping on the map and hit "direct to". Only then it´s possible to add some more waypoints. After leaving the flying mode the route stays and it´s possible to add also waypoints in planning mode.
Starting/planning a route by the menu "route"->"create route" is working normally.
This problem exists on my IPad 4 as well as on my IPhone 6s‌‌. I tried already to delete and reinstall SD - didn´t help. Also I updated my IPhone - same.
Does anybody have an idea?
Thank you!
Marc‌‌‌‌‌
efrenken
efrenken
Posts: 265, Visits: 3.5K
Marc, no idea. But here it works ok as usual.
Current versions:
SD 3.8.5
iPad Pro WiFi + Cellular iOS 11.1.2
Eric
Edited 12/3/2017 12:31:33 PM by efrenken
mwitt
m
Posts: 3, Visits: 0
Hey Eric,
thanks.
‌‌I also thought about other software on my devices. But I didn´t install any new software or firmware update.
Best,
Marc‌‌
Posts: 8.1K, Visits: 9.3K
This is a known bug in the current public version. The fix is in the next version, coming in the next week or two.
mwitt
m
Posts: 3, Visits: 0
Tim Dawson - 12/4/2017 12:48:15 PM
Thanks for the fast respond.
