Whats here in 3.8
rg
rg
Posts: 109, Visits: 1.9K
Tim Dawson - 5/11/2017 11:20:01 AM
Yes, it is bad. That's exactly how we would do it (and how we do it for PLOG frequency inclusion) and it was bad, so we didn't include LARS in What's Here.
Mike, there isn't a one-to-one mapping of listening squawks to airfields. It's a mess.
Fair enough.
EHOW flyer
EHOW flyer
Posts: 66, Visits: 215
Since there is more information available with only one tap, the 'Whats here' block is also grown in size. Therefor overlapping the chart behind, Normally no problem, but when you want to check the contours of an airspace you have to do this via the Whats here function and so the airspace to be checked is overlapped by the WH block.
I‌ suggest to make the WH block moveable after the first show-up, or to make it by some degree transparent.
Is there a reason why once you have displayed the airspace boundaries, you cannot simply dismiss the What's Here screen so you can scroll the map as you like?
EHOW flyer
EHOW flyer
Tim Dawson - 5/15/2017 3:04:31 PM
The fact is that the (via WH) selected highlighted boundary is overlapped by the WH screen, therefor preventing to check the boundary as requested (except for the parts extending beyond the WH screen). The highlight will vanish in a few seconds and you have to start again. Simply dismissing is not the issue...
flieger-claus
flieger-claus
Posts: 15, Visits: 47
I cannot see the nice airspace stack - Android , Skydemon 3.8.0.18997
Do I have to switch on somewhere?
Thank you for  advise!
Claus‌‌‌
I believe the requested highlight is shown for ten seconds, which should be plenty of time to hide the What's Here screen and pan around the map. The idea is that the highlight makes it clear exactly which piece of airspace is being referred to in the What's Here screen.
Claus, the airspace stack is only shown if there is sufficient room to do so. Typically on phones, there isn't enough room for it.‌‌
Pete
Pete
Posts: 129, Visits: 966
Not convinced of it's implementation on the PC version.
H‌ow is this better than the previous small box, black on white, same font??
Pete, did you deliberately go out of your way to find somewhere without a lot of information available, to take your screenshot?
Is your poi‌nt that the new display can be larger?‌
Pete
Pete
Tim Dawson - 5/16/2017 1:54:06 PM
Absolutely! ;-)    My point is that in the previous version it would resize to succinctly display the required info.
‌This just obliterates a large area of the screen  whatever the info,......... IMHO a backwards step in the PC implementation.
F‌urther, the different sizes of fonts and colours to not display and contrast as clearly as before, but maybe that's an issue with my screen.....sorry, just don't like it.
Edited 5/16/2017 4:10:49 PM by Pete
flieger-claus
flieger-claus
Hi Tim!
Thank you for your fast answer.
‌I use a 7" Tablet - A‌sus Memopad HD7: That should not be too small. I would like to see the stack in the future...
best regards Claus‌
