Visits: 202
Since there is more information available with only one tap, the 'Whats here' block is also grown in size. Therefor overlapping the chart behind, Normally no problem, but when you want to check the contours of an airspace you have to do this via the Whats here function and so the airspace to be checked is overlapped by the WH block. I suggest to make the WH block moveable after the first show-up, or to make it by some degree transparent.
