Pop up comment
Skyboy999
Skyboy999
Posts: 58, Visits: 239
Would be useful to be able to insert a free format comment into planned route and for this to pop up for acknowledgement when in proximity.
efrenken
efrenken
Posts: 265, Visits: 3.5K
Nice one, gets my vote.
Eric
Gax
G
Posts: 41, Visits: 0
Absolutely! One example would be a prompt I could use for French radio calls as you get near a french-only airport, or airstrip details not stored in the database.
Martin Bech
Martin Bech
Posts: 152, Visits: 352
Gax - 4/18/2017 12:36:27 PM
Get my support! Since SkyDemon will not implement a "remember to close flight plan" switch/popup, this option could be used.
JoelJacob
JoelJacob
Posts: 13, Visits: 28
I have already asked for this one times ago.
‌‌In France, for example, you have a huge number of Danger Areas or Restricted Areas that need a prior radio contact with the Military zone manager (using a specific frequency, of course) if you want to transit.
IMHO, the best way to implement it is to add a "comment" field to the waypoint dialog. The comment should be displayed when hitting the waypoint and printed in the PLOG (and saved with the flightplan of course).
Skyboy999
Skyboy999
Thanks. Still think this has much merit but I fear lack of supporting replies will mean it won't be taken forward.
So, fellow forum members, if you agree, then please support.
Ashkirby
Ashkirby
Posts: 14, Visits: 46
Sounds like a useful idea to me, definitely something I would use!
derWessi
derWessi
Posts: 63, Visits: 157
+1
Nice‌ Idea. ‌
There could be two kinds of trigger points: waypoints on the route and user defined triggerpoints that are independent from an active route. There should be also the possibility to define the trigger radius together with the message.
Pigei
P
Posts: 10, Visits: 38
Any useful and personal remind linked along the planned route can strongly help the pilot in cross-check
Pigei
P
JoelJacob - 5/29/2017 10:00:12 AM
I think the better solution could be the creation of "Notes" (with specific icon) linked to a route in the flight plannig phase.
